brakes and steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2002, 06:42 PM
New Member
Post brakes and steering
1932 ford pickup ijust put in ifs with mustang II
steering 4 bar rear susp ford rear drum brake set up any ideas on what front disc brakes i should use the truck is very light in weight any tricks on suspension sure cloud use the help.
thanks wiz.
Old 08-17-2002, 11:44 PM
aka Duke of URL
Post
It would be the easiest to use the stock MUST II setup, but it is a small dia. rotor. There are kits (Fatman Fabrications) to use a larger chevy rotor and caliper on the FORD spindle.
Old 08-22-2002, 02:51 AM
deuce_454's Avatar
Post
I did a search and came up with several companies that does a conversion to 11 inch rotors with chevy bolt pattrens the price for 11 inch rotors and gm callipers is 169 usd. try
http://www.midnightauto.com/brake_system.htm
Old 08-28-2002, 05:03 PM
New Member
Thumbs up
thanks for the info every bit helps just so you know i found biger brake rotors from jims rod shop i went to ford granada disc's
thanks wiz
Old 08-29-2002, 01:44 AM
aka Duke of URL
Smile
[quote]Originally posted by wizard1932:
thanks wiz<hr></blockquote>
Well...if you went to Granada spindles and aren't happy with the single piston sliding caliper, how about <a href="http://www.woodyg.com/fairlane/finfo/discs66.html" target="_blank">-this-</a>?
Kinda cool, eh?
Old 09-02-2002, 11:00 PM
deuce_454's Avatar
Post
well I like the info KULTULZ but it does not apply to the mustang 2 in stock config, as the MII has front steer spindles ie; rack is in front of crossmember. but the granada is rear steer, ... box in rear of crossmember. the info is great for anyone wanting to stick the rack and pinion behind the crossmember, but does not work well on a stock M II..
Old 09-03-2002, 02:23 AM
aka Duke of URL
Arrow
[quote]...well I like the info KULTULZ but it does not apply to the mustang 2 in stock config<hr></blockquote>
I only gave the information regarding the FORD calipers as an alternative to using GM calipers. The poster decided to go to GRANADA rotors to increase rotor size easily.
An adaptor can be fabricated for the MUST II spindle and the larger Granada rotor.
I believe this is what he has posted, that he has put Granada rotors (11") on MUST II spindles.
Hey! We FORD guys must maintain some semblance of self respect...
[ September 03, 2002: Message edited by: KULTULZ ]</p>
Old 09-03-2002, 08:52 AM
deuce_454's Avatar
Post
i know, i am useing a FoMoCo mustang II front end in my 32 ford, and i am indeen running granada 11´´ and a pair of old willwood dynalite II i found at a swap meet.
and the info is going to come in handy when i have to replace brakes on my dads 65 mustang, (that i built but sold to him to afford a hotrod build)
incidently i found out that a rack and pinion form a european Opel (GM) Ascona C, or Vectra A fits a 64-66 mustang.. saving about 2500 dollars over buying it from total controll inc. just some brackets and its in there..
Old 09-05-2002, 05:29 PM
Post
Speedway Motors has an easy kit to put 11 disk brakes on you car. I used one on my '34 coupe and it works very well. The kit includes everything, rotors, calipers, pads, brackets, bearings, nuts and bolts for about $265.00.
This may be too late but hope it helps.
Old 09-06-2002, 06:41 PM
New Member
Post
hey you guys gave me a lot of info thanks just to clear it up im just looking for witch biger disc to use i have ifs front susp custom tube a arms and spindles that should use the grnada rotors.
thanks wiz.
