brakes sticking - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2007, 05:56 PM
TailGater's Avatar
Blood, Sweat, and Gears!
brakes sticking
I've got a brake problem on a 97 neon, the caliper on the right front is sticking on, I just replaced the caliper and pads but its still sticking on, I noticed if I loosen the bleeder screw on that side the brakes release, does this sound like the rubber line is collapsed? is there any way to check it? The line looks fine, no cracks or anything in it that I can see.
Also when I took it for a test drive with the new hardware, I noticed when the brakes are applied the car pulled to the left so it seems even though the right caliper is sticking, its not grabbing any harder when I apply the brakes.
I know its not a hot rod, but I appreciate any help you guys can give me.
Thanks
Old 07-25-2007, 07:20 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
That swelling inside the line is common on some real old cars. Fluid can pass under pressure, but not retract. Take it off and see if it's plugged.
Old 07-25-2007, 07:37 PM
TailGater's Avatar
ok so i did take it off, and as soon as i did fluid started draining out of the hard line, nothing came out with the rubber line hooked up so it looks like the rubber line is my problem.
Thanks F&J
Old 07-25-2007, 08:37 PM
milner's Avatar
the easiest way to check flex lines, is to open the bleeder, with the master cyl cap off, and watch for a steady flow of fluid. if it drips for a few seconds and quits, the hose is probably plugged. the reason it pulls the opposite direction, is because that car has diagonal brakes, which means the two front brakes are not connected together. but by now you probably have the problem solved. happy motoring.
Old 07-27-2007, 03:41 PM
TailGater's Avatar
Just thought i'd update this, I replaced the flex line this morning and the car stops like a champ now .
Thanks guys
Brakes sticking RodFather Suspension - Brakes - Steering 1 02-27-2007 12:13 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 07:29 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 01:37 PM
54 chev pickup front brakes sticking DV8 Suspension - Brakes - Steering 0 04-19-2004 02:02 PM
newport sticking brakes ian marsh Suspension - Brakes - Steering 0 12-22-2003 11:40 AM
