Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brakes stop very slow
Old 10-07-2012, 07:42 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
Originally Posted by adantessr View Post
It sounds like the booster is bad to me also. As already mentioned, a new booster W/O master cylinder should be less than $100.oo . First though, I would make sure that the vacuum check valve on the booster is opening. Just pull it out of the booster leaving the hose attached and make sure you are pulling vacuum. Let us know.
It should suck air with the engine on? I've already checked it and it was pulling air when I took it off the booster.
