Brakes stop very slow
So I went to help guy with his brakes on 80 Jeep truck. The problem is that it takes forever to slow down the truck. All the pads/shoes are good (front pads were replaced), we bled system and pedal is firm. However if you try to stop it just won't stop, takes long time for it to stop.
Is master cylinder bad? I unhooked vacuum line to booster (it has power booster) and it has suction. |
Artificial Intelligence is no match for Natural Stupidity Chet |
pads were worn evenly. If I pump up brakes with engine off and then turn it on, brake pedal does not go down a bit. I guess it is a bad booster?
Is brake pedal effort high? Maybe th booster isnt your problem.
First thing to do is lift the truck, apply the brakes, and make sure both systems are working. If the combination valve is shuttled, one system wont be functioning. If the front system is shut off, you lose 60% of your braking system power. Inferior brake pads can cause a low friction co efficient, causing a very diminished stopping power, even with ample pedal application pressure and assist from booster. If you uhook the booster ( be sure to block vacuum hose so motor doesnt stall) and the pedal is much harder to push to obtain the same stopping distance from a set speed then the booster is obviously multiplying the effort applied to the pedal.A booster can hold vacuum and leak when brake is applied resulting in loss of assist, They can also hold vacuum and not apply any multiplication of force. If you are pretty much applying brakes as hard as you can, and the truck takes forever to stop, it could be the pads are inferior. If the booster is bad, you should still be able to stand on the brakes and make the wheels to skid. You might try that on a dirt road and have a friend watch to see that all 4 can be locked up.That is a good way to determine that all 4 are working.
Fact is stranger than Fiction |
He lives on a gravel road. Pushing pedal as hard as I could it didn't lock up brakes.
I pumped up brakes and then started the truck and pedal didn't move at all, which makes me believe booster is bad. |
It sounds like the booster is bad to me also. As already mentioned, a new booster W/O master cylinder should be less than $100.oo . First though, I would make sure that the vacuum check valve on the booster is opening. Just pull it out of the booster leaving the hose attached and make sure you are pulling vacuum. Let us know.
Yup. I'd replace the booster.
Booster was replaced and brakes work as they should.
I didn't know that new booster was already adjusted to spec and adjusted it to the one on the car. Old one someone tried to "fix" by putting a piece of saran wrap to "seal" it off. Some redneck ingenuity there... |
| rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin | calon | Introduce Yourself | 2 | 01-23-2011 06:52 PM |
| hard pedel slow stop | campracing | Suspension - Brakes - Steering | 10 | 12-22-2009 08:09 AM |
| Brakes pull right, Brakes pull left, I want to stop straight. | 57 Chevy | Suspension - Brakes - Steering | 7 | 07-23-2006 05:00 PM |
| No brakes when I went to stop! | fastrehotrods | Suspension - Brakes - Steering | 7 | 04-03-2006 06:46 PM |
| Does The "Stop Leak" Stuff Stop the Rear Main From Leaking? | daveh | Engine | 7 | 08-02-2005 08:43 PM |
