BRAKES WON"T HOLD - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2012, 02:07 PM
BRAKES WON"T HOLD
I know this isn't a hot rod question as such so I apologize.
I have a 94 Honda Accord with 4-wheel ABS brakes. The brakes work just fine except when stopped for a long time such as at a traffic light. The pedal will slowly go down which allows the car to creep forward. I've bled the master cylinder, replace it, bled the brake system including the ABS unit. I finally had a mechanic check the system. He, like the book and on-line mechanics, say the problem is the ABS unit. A new or rebuilt one cost more than the car is worth and a used one may have the same problem. Any thoughts or experience in this area?
Ossie
Old 06-01-2012, 03:42 PM
SublimeRT's Avatar
If you're sure that's the problem and looking for a cheap solution (sounds like it) then just remove it. Complete the brake line connections with brass blocks or run new lines.
Old 06-02-2012, 09:57 AM
I found a new one for around $350..
http://www.dealerdirectparts.com/199...ccord-ex-5.htm
Or just take out the ABS...Yeah it helps but its not like the chances of getting in an accident are increased that much, i know it sounds sketchy but do what you feel.
Old 06-02-2012, 10:09 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I cringe at the thought of anyone suggesting modifying a factory brake system. Yes, it "may" work as suggested but there could be some liability involved if an accident ever does happen. Fix it right or park it!!!!
Don't suggest any repairs or modifications that will potentially cause harm to anyone. Your suggestion to remove the ABS system is like telling them it's ok to crawl under a car while on a jack. You might get away with it once, a few times or many times but eventually you will pay the price of not doing it right.
Front brakes won't bleed redneckhotrods Suspension - Brakes - Steering 2 08-14-2010 10:41 PM
"service brakes" light won't go out Arrowhead Suspension - Brakes - Steering 4 05-12-2008 06:45 AM
My 700R4 won't hold first (low) gear! Bayley Transmission - Rearend 5 05-30-2006 11:22 AM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
will the rear end hold up" leamichael Engine 1 05-30-2002 09:13 PM
