Brakes wont hold pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2013, 04:16 PM
Newbie37's Avatar
Newbie 37
Last journal entry: Three months since started
On my 37 chev i put four wheel disc brakes, all new lines with 2 psi pressure valves, new master cylinder and proportioning valve from speedway specifically for 4 wheel manual disc brakes. Bled the system several times both manually and with pressure bleeder and i can pump up the brakes and they hold but as soon as i release them it goes to the floor on next attempt to put brakes on, any help would be appreciated.
Old 10-05-2013, 10:06 AM
S10xGN's Avatar
Gotta love a turbo!
That's a symptom of the master cylinder's volume being inadequate for the wheel cylinders. Have you looked at the technical info on Wilwood's site? I believe they show how to calculate the necessary m/c bore so it has enough fluid to actuate the calipers on one stroke. It could be other things... Have you mounted the calipers with the bleeder screws at the top? If they're even off a little, air cannot be fully purged (I know this from experience).
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
Newbie37 (10-18-2013)
Old 10-20-2013, 09:35 AM
Newbie37's Avatar
Newbie 37
Ok , so i changed my setup, went to power four wheel disc , new master cylinder and booster on firewall. After many attempts to bleed system and no success i decided to plug off rear brake line trying to figure out where my problem is and i have good pressure and brake on the front but when i connect the rear line it goes to the floor instantly. I looked for leaks in the rear lines but dont have any. Tried pressure bleeding and manually bleeding the rears again but no different. What am i missing? Is the combo valve bad? Is the master bad? Do i have a kinked hardline. Please help. Im very frustrated
Old 10-20-2013, 10:50 AM
Newbie37's Avatar
Newbie 37
The front disc brakes are a mustang II , rear kit is from speedway for ford nine inch rear end. I tried bypassing the rear line straight to the master cylinder and still np pressure to rear brakes. Disconnect rear and plug master and fronts are good. Rear caliper part numbers are. 91031046L. 91031046 R. Master cylinder and booster i bought from rodparts as a combo unit. And yes the calipers bleeders are on top. Lol. I am using a combination valve. Should i be using just a distribution block?
Old 10-20-2013, 11:21 AM
Newbie37's Avatar
Newbie 37
I vacuum bled and manually also. Checked for play on the rod and i have maybe 1/8 play. I also removed the cap on the master and pump the brake and it shoot up from both sides of the master so its definitaly opening both sides for flow.
Old 10-20-2013, 11:44 AM
Newbie37's Avatar
Newbie 37
Got fluid out of rear calipers, combination valve is the proportion valve, block all in one, and i dont have a clutch lol
Old 10-20-2013, 11:49 AM
S10xGN's Avatar
Gotta love a turbo!
With a problem like this, I'd recommend starting over. Bench-bleed the master first, you can do this on the car the "old way" with loopback lines or the new way by using plugs in the outlet ports. I've used both methods and prefer the loopback lines. Those plastic plugs seem like they'd blow out under pressure but seem to work OK. Any air will come from the lines, the inner ports, or both. Once you see no more air bubbles, connect the lines and let them gravity fill by cracking open the bleeders while NOT letting the master run empty. Once you get fluid at each bleeder, close that one until all are closed. Now try bleeding the system. Are you getting good fluid flow at each bleeder? Are the bleeders at the highest point (top) of the caliper? If they are off even a little, trapped air will not be purged correctly. You can also help moving the bubbles by rapping the calipers with a deadblow hammer...
HTH,
Russ
Old 10-20-2013, 12:08 PM
Newbie37's Avatar
Newbie 37
Ok guys thx for the input, enough for today, football games going to start lol. Tommorrow i will start over from the beginning.
Front BRAKES Won't hold stinkin linkin Suspension - Brakes - Steering 6 04-14-2013 12:36 PM
BRAKES WON"T HOLD Ossie Suspension - Brakes - Steering 3 06-02-2012 11:09 AM
1988 Chevy, 700r4 Wont hold in first gear. jjack010 Transmission - Rearend 10 02-23-2012 08:18 PM
Help! Brakes wont build pressure... they did before I replaced the lines? honster919 Suspension - Brakes - Steering 6 06-06-2011 09:23 AM
How long does your pump hold pressure? 001mustang Engine 9 12-31-2009 12:32 AM
