Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Braking solution for 1983 Silverado. Help
Old 04-24-2012, 04:15 AM
dsgb610's Avatar
dsgb610 dsgb610 is offline
I be Strokin!!!
I currently have 295/50/15 tires all around. The rear end is a drum axle with limited slip and 3.73 gears. (5-Lugs) Do you have a link for the stainless steel brake lines? For now I plan on going with the brake lines, ceramic pads and bigger rotars.
