brand of body filler, primer, paint to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2004, 02:34 AM
montea's Avatar
tryn to learn
what kind of body filler, primer and paints do you guys use? and what stores to go to.
im going to start the body work on my 82 Grand prix and i need to decide on what to get.
Old 05-18-2004, 02:41 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
i use rage filler from Evercoat. they also have a finish filler thats so creamy.
so far, i've only used ppg paint. no complaint with the paint, just the painter.
i got it at a local body shop. call around, you may be surprised.
Old 05-18-2004, 11:49 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
A search will get you many responses to this question as everybody has their favorites- I like Evercoat also, but good stuff can be had at NAPA with the CUZ fillers and Tech/Base or Cross/Fire systems. Look at many and buy the best you can afford!
Old 05-18-2004, 06:50 PM
302 Z28's Avatar
I agree on the Evercoat products, the best I have used, mixes well with almost zero air bubbles. Ditto on the PPG products also, as good as anyones. Whatever brand you decide to go with do not mix brands. Use the same brand primer as the paint you will be using. It eleminates any compatability problems.
Vince
Old 05-19-2004, 09:31 PM
New Member
For filler I use the stuff at Napa. I think it's called Microlite, or something like that. It's a little expensive, but I've heard it's some of the best stuff you can get.
Old 05-20-2004, 08:47 PM
sportbikeluvr's Avatar
Hey can those Evercoat fillers be used on plastic body work (ie. motorcycle)????
Old 05-21-2004, 10:09 AM
302 Z28's Avatar
Yes, if the surface is prepared properly.
Vince
Old 05-21-2004, 12:59 PM
New Member
i use evercoat Rage gold and evercoat z-grip fillers and evercoats metal glaze as a finishing putty. they all work great and all can be put over plastic. I have seen the z-grip used over lead also, but if using it over lead wait over night so that its fully cured. as for primer, i have used all in the BASF line. but as a middle grade Diamonts DP26 is a good one and u can also use it as a wet on wet sealer and it is also tintable.
Old 03-26-2005, 10:12 PM
rick458's Avatar
Wookie
Is the Evercoat Rage Gold good for skim coating?
and what is the working time with it?
Old 03-26-2005, 10:50 PM
montea's Avatar
tryn to learn
this thread is almost a year old now, would of been better to start a new thread
Old 03-26-2005, 11:01 PM
The fillers at NAPA ARE Evercoat products. The top of line "Tec/bodyfiller" 6378 being RAGE (GOLD I believe).
