Brand new 16 ga. bare metal coating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2004, 03:40 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
I just got my new truck box for my '40 Ford and spot welded it together, now I'm ready to prime it to keep the surface rust off till I paint later this year. Anyone have a recomendation for surface prep and primer. Epoxy or acid etch? Have to do inside the stake pockets and rolled tube edge too. Spot welds are ground and ready forspot putty.
Old 10-30-2004, 12:01 PM
Tazz
Buy a gallon of metal etcher/morph and wipe it on then wipe it dry. You have finished grinding and filling haven't you? Then your ready for primer. I like the epoxy primer too seal the surface before appling paint...seals the metal for a good long time from the elements...just in case you don't get to painting right away!!!
Tazz
Rat Rods Rule!
Old 11-02-2004, 03:11 PM
Wiki Edits: 647
Thanks Tazz,
Any particular make over another or are they pretty much the same.
Old 11-02-2004, 03:52 PM
My feeling would be skip the acid.
But that is up to you.
I would wash with wax and grease remover than DA the metal with an 80 grit wash with wax and grease remover let set about 30 minutes than apply a good epoxy.
Barry
Old 11-03-2004, 11:45 AM
Wiki Edits: 647
Barry, any suggestion on how to blow in the stake pockets and rolled edge ?
Old 11-03-2004, 03:25 PM
Hopefully there are better ways out there
but what I have done in past is mask off hole (for runs) and turn the fan adjustment in to a straight line (no fan) lower air pressure and just shoot in hole best you can
Old 11-03-2004, 03:38 PM
Wiki Edits: 647
I was thinking of using a piece of sea sponge tied in the middle of a piece of string, dipping it in epoxy and then pulling it back and forth in the rolled tube. For the stake pocket, stapling a sea sponge to a paint stick or dowel and dipping it in epoxy and dapping the stake pocket.
What do you think the chances are of epoxy sticking on to the lower gate pins and housings? I would hate to see rust forming.
