Brand new 351M need an expert for help lots of questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2009, 06:56 PM
I installed a brand new 351M in my 1977 Thunderbird town landau. I bought this engine about nine months ago, installed it and never got it running right, thought that it might have been a vacuum leak but never really traced it down cause I was going to replace the intake and carburetor anyhow. So I did replace them with an Edelbrock performer 400 intake and an 750cfm 4bbl Edelbrock carburetor. As it sits now, those parts are installed but nothing is hooked up on the carb. I had to take off the distributor to install the intake and stabbed it in just to keep it airtight. I was told to get an aggressive cam for the carb or ill just flood it. I just need some guidance on what to do with it. I also bought a full set of Comp Cams push rods, Edelbrock valve springs, and a few dress up parts. I have real down to earth expectations for this car, not wanting it to be a track car, just one with a roar under the hood, and a good takeoff. Any help would be greatly appreciated, Thanks-Chris -aka-ThunderChicken
Old 01-24-2009, 07:43 PM
runn141's Avatar
that particular carb will drown a motor. a 600 is probably better if you want to drive this car sensible at times. here is what you need to hook it up.
http://www.edelbrock.com/automotive_...throttle.shtml
Old 01-25-2009, 09:55 AM
That engine has pitifully low compression.
I recommend a 4x4 cam from CompCams as a maximum.
I'd use a 600 Edelbrock,
(or a 600 vacuum secondary Holley).
Of course you will need a full distributor timing curve done.
Lots of Clear Questions 1958FordF100 Body - Exterior 18 03-07-2006 08:47 PM
Lots of Blower related questions?? HemmiGremmie Engine 5 11-13-2005 05:15 PM
First timer with lots of questions MrFurious Body - Exterior 1 05-27-2005 06:59 AM
New to boards, '74 Camaro, lots of questions (long) Felix_the_caT Engine 12 04-27-2005 03:21 PM
Lots Of Questions Justin Mc Interior 2 11-30-2004 01:10 PM
