LinkBack | Thread Tools |
They do get hot.
Artificial Intelligence is no match for Natural Stupidity Chet |
Hot lips indeed ..LOL , yes they can get hot with a load and you had that happening. I have never personally hand tested them cause I always figured if they were charging that was all good, no smoke not to hot. 1000 rpm idle you are pushing some HP there, under hood heat could also be adding to the temp.
Had an issue with my new alt getting ext hot, like your talking about, and the battery would go flat in 2-3 weeks...... solution.... I had switched the wires on the alt by accident and the voltage reg was grounding it's self out, I switched them to the correct sides and poof no more hot alt
you should check the voltage and the current output to be sure it isnt staying Maxxed out causing the heat problem, yes they do get hot, better to do a few quick checks to be sure there isnt something else going on though. Just a thought.
Your alternator should not exceed 150C (302F). Beyond that the varnish on the wire may start melting and the diodes in the alternator will short out. 100C is boiling point of water. Alternators can handle a lot of heat.
| wire terminal broke off 2-wire alternator | bullheimer | Electrical | 3 | 10-11-2009 10:22 AM |
| how do you wire up a temperature sending unit? | c&cderby | Electrical | 6 | 08-23-2009 04:46 PM |
| Powermaster Alternator Wiring | mrdreex | Electrical | 6 | 12-31-2008 01:13 PM |
| normal operating temperature | Danscam | Engine | 4 | 03-16-2007 08:28 AM |
| New Powermaster alternator, broken? | arch | Electrical | 2 | 06-12-2004 10:38 PM |
