Which brand of tape - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 09:08 PM
mitmaks's Avatar
Last journal entry: Grille
Which brand of tape
Which brand of tape do you prefer and why.
Which tape you don't like and why?
Old 03-20-2013, 09:37 PM
put up or shut up
I like 3M cause it sticks well and peels off the roll with no issues.
Old 03-20-2013, 09:59 PM
mitmaks's Avatar
3M makes a lot of different tapes, which one in particular?
Old 03-20-2013, 10:08 PM
put up or shut up
don't know the model number. It's a bright yellow color. That tape rocks.
Old 03-20-2013, 10:44 PM
mitmaks's Avatar
We use green tape at work, it's not the best imo but it works ok.
Old 03-21-2013, 06:07 AM
milo's Avatar
point on positive
American Brand automotive in 3/4 and 1 3/4...turns tight corners , and sticks outstanding and to itself well.. Probably the one off brand or unknown thing I use they say it even cost less as if that's a factor..you'll never here anything bad about it cept things like "I never heard of it "
It truly is the Cadillac of tapes...
clicky --> American Tape PG272 2" Premium American Masking Tape 1 case of 24 - American Brand Masking Tape
The others including 3M's best, don't stick well, bleed under, lift at the wrong time, can't turn as tight a corner without ripping, harder to remove if left in sun or booth and go through a coulple heatcycles.. don't stick well to themselves and cost as if that's a factor..
Old 03-21-2013, 06:22 AM
Trucknut's Avatar
I like 3M green.
Old 03-21-2013, 06:59 AM
BarryK's Avatar
I agree 100%, I have been using PG27 since it was first available in the automotive market, sometime in late 80's or early 90's, main reason is learned long ago avoid buying 3m at any cost but that is just my 2cents worth.
Not a big user but we go through 2-3 cases a month at plant in testing and at home I go through about a case a year of the 3/4".
About 3 years ago I was at a friends body shop out of town, we were after hours drinking a beer or so and he was taping a car, I offered to help, he had 3m, fought that stuff for 20 minutes and said, you tape and I will watch, I'm a pretty good and fast taper but I could not make the stuff work and I was looking like a beginner.
Old 03-21-2013, 02:52 PM
TucsonJay's Avatar
3M green. Sticks great, and the 1/8th inch sticks better on curves than the plastic tapes.
Old 03-21-2013, 03:31 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Jay I like the old 3M manilla and the 3M green and man are you right about the plastic tape I learned the hard way the first time I used it and the second time when I thought it was me and not the tape LOL You cant emagin being in the middle of doing flames and seeing a curve in the flame having the tape start to UN CURVE I'll stick to what I know works well for me LOL
I guess when you use any tape it becomes second nature and you learn the characteristics and when changing or using something else its a learning curve! So to you that your tape works for your methods stay with the brand you like!LOL
Jester
Old 03-21-2013, 05:47 PM
mitmaks's Avatar
Ya, I was using this 3M Green tape for some house painting projects and it just bleeds paint under. I don't like that at all. Good thing I don't use it for graphics etc on the car. Imagine what that would look like
Old 03-30-2013, 10:21 AM
JoAnnBortles's Avatar
I love the American tapes I use. Their AM tape, Aqua mask which is blue in color is my favorite. The OM, orange Mask is great also. The Aqua mask was designed for use with waterbased paint, but I use it for working with solvent base also.
Old 03-30-2013, 11:00 PM
My favorite is also Aqua mask.
Old 03-31-2013, 08:56 AM
Last journal entry: Steering
Colad Tape.
this stuff is the best. No adhesive transfer, no creep back. You can mask around a dime with it. And stays where you put it.
Old 04-12-2013, 08:01 PM
Last journal entry: Several Car Projects
3M green tape is named 233+
Masking, Automotive Masking Tape, Plastic Sheeting, Masking Paper, Booth Coating, Foam Masking, Jamb Masking, Dirt Trap
Basting Tape Elleka Interior 2 03-05-2010 10:37 AM
masking tape zephyrc Body - Exterior 4 11-07-2008 09:40 PM
Timing tape came off? madbrad Engine 2 02-14-2008 05:36 PM
name brand vs off brand solid lifters??? btp76 Engine 14 01-02-2005 08:33 PM
Dualloc tape 5window Interior 17 02-15-2004 06:16 PM
