Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brand of weld thru primer
Old 01-12-2006, 06:22 AM
modas's Avatar
modas modas is offline
Dazed and Confused
Last journal entry: Trunk Part 21
Hi Guys -
I'm getting close to starting the inner/outer rocker work on my Impala. In fact, my new pieces should be arriving tomorrow . Anywho, my plan was to spray the inside surfaces of the inner/outer rockers with a spray bomb weld thru primer from NAPA. I think (if I remember correctly) it was heavy in zinc and created kind of a galvanized surface.
My other thought, was to mask just the areas that were going to be spot welded the epoxy prime everything else, THEN remove the mask, mask the expoxy primer, then spray the rest with the spray bomb weld thru.
Would the spray bomb weld thru primer give me sufficient protection or should I be doing this differently? I certainly don't want to do this again in 10 years
Much Thanks!
Joe
Thanks for the help
