Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brand of weld thru primer
Old 01-12-2006, 06:31 AM
chadsbodyshop49119 chadsbodyshop49119 is offline
Custom builder and painter
Last journal entry: Another test fit of the axle
IMO.. your much better off with the epoxy.. weld thru is porous untill you get it hot.. so it doesn't help much except around the area's you weld.. i'd suggest self etch if you must spray bomb... but still say epoxy is better.. if you must spray bomb.. the wurth seems to work about the best imo.. and they have the same product labeled as specialty.. if you can find it good luck..
