Brass Fittings supplier - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2013, 10:24 PM
Last journal entry: More information
hey guys,
do any of you have any fitting suppliers you use? I know of swagelok and mcmaster carr -- but carr is very expensive, and for simple fittings i feel like there has to be a better source out there that I might be missing.
Specifically I'm looking for a metal tee that is 5/8x3/8x5/8 -- it's a surprisingly hard item to find. I know they exist though, because I found a supplier for LP Gas cars in Australia & New Zeland that sell them (just expensive after shipping).
Do you guys know of any place I could look to find fittings?
Thanks!
Old 06-08-2013, 11:35 PM
evolvo's Avatar
Heathen
Are you talking about NPT threads? Because 5/8" NPT does not exist as per ANSI NPT- National Pipe Thread Taper- ANSI B1.20.1. There are 5/8" barb hose fittings, is that what your looking for?
Old 06-09-2013, 01:04 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
1/2 and 3/4 nominal pipe size are readily available and All you need is the tee and the appropriate bushing and you are in business..i suppose this is for an airline..
Sam
Old 06-10-2013, 01:34 AM
i'm specifically looking for a hose barb tee. My heater hose is 5/8, and i need to run a spur from the heater hose to my steam pipe running from the back of my heads. It's in effort to clean up the engine bay a bit.
This is the tee i'm looking for:
5/8x3/8x5/8 Brass/Metal Water TEE - Blue LPG Shop
Old 06-10-2013, 07:08 AM
Greg T's Avatar
www.krusinklassics.net
Why not use plastic?
Old 06-10-2013, 09:36 AM
What does the 3/8" hose connect to? Can you switch the other end of that hose to a 5/8" barb and just use a 5/8 x 5/8 x 5/8 tee fitting? Seems a lot easier to find.
Old 06-13-2013, 01:57 AM
i ended up just using a dorman plastic part -- the end that the 3/8 hose comes from is the steam pipe at the back of the heads, which i eliminated with a couple JIC barb fittings and teed into the 5/8 heater return hose (going to my header tank, just like like my steam pipe used to do).
Old 07-10-2013, 01:46 AM
i just wander into my local Ace Hardware and get all the brass fittings I need from their plumbing section
like this Tee setup I added to run an oil pressure gauge as well as my factory idiot light.
http://home.comcast.net/~kc8oye/Engi...tch2_small.jpg
Old 07-10-2013, 09:26 PM
try randall systems in st charles , il. ask for scottie. he's into hot-rods and such, so he will probably have what you are looking for.
Flared Fittings vs Compression Fittings... awbazar Hotrodding Basics 17 11-08-2010 08:51 PM
Use of Plastic or Brass Fittings in Fuel Line? JohnTN General Rodding Tech 8 11-02-2007 10:57 AM
