break error light on 78 camaro? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 01:29 AM
hcker2000's Avatar
Hey all I was wondering if any one would have any clue as to what would cause the break error light to come on in a 78 camaro?
I can think of a ton of stuff that might but I dont know what kind of error sensors a 78 camaro would have. So I'm hoping some one can narow it down a bit for me so I can get it fixed.
Old 05-29-2006, 06:49 PM
abstruse dutch uncle
The light is connected to two different circuits.
One is the parking brake switch, the other is a pressure differential switch.
The pressure differential switch is located in the combination valve... the block where all the brake lines come together. If the switch pin is grounded to the block body, the light will come on. It will do this due to a fluid leak or bypass. The problem must be found and repaired. The valve may reset automatically, or it may need persuation according to factory manual.
The parking brake switch just completes the circuit when that brake is on.
If there is a short in either circuit the light could come on.
Old 05-29-2006, 06:56 PM
hcker2000's Avatar
Ok thanks for the info that will sure help out. I have a sneeky idea it may be the parking break switch. At least thats the one im gona check first.
Now if its the other issue how hard do you think it will be to fix it?
Old 05-29-2006, 07:04 PM
poncho62's Avatar
Wiki Edits: 5
If the emergency brake is not totally released, the light will stay on........pull up on the emerg brake pedal.
Ontario Rodders
Old 05-29-2006, 07:06 PM
Depends on the cause. Check the fluid level in the master.
Normally on the GMs, if it's working right, the swich will offset when you put on the brakes, and the light will come on, but when you let off the brake, it goes out. Sometimes it gets stuck on, or you might have one that doesn't reset itself.
An offset differential switch could be caused by anything from a bypassing master to a leaking slave cylinder, or anything in between leaking. Or it can offset and stick during routine brake work.
Unplug the parking brake switch. If it's in that circuit, the light should go out. If it doesn't, unplug the wire at the combination valve. If the light stays on with both unplugged, you might have a short.
edit: d'oh, and first do what Poncho62 said
Old 05-29-2006, 07:09 PM
hcker2000's Avatar
Thanks for the tips. I will get on it. So far the car still stops ok but i dont wana get to the point where it dosnt.
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
Fixing a door latch on a 78 camaro? hcker2000 Hotrodding Basics 3 12-12-2005 07:19 PM
78 camaro project myrl Engine 4 07-23-2005 07:13 AM
4sale, 78 camaro doors/hood/f.bumpr bullheimer Body - Exterior 4 11-17-2002 01:46 PM
78' camaro 350 or 305 atvloco Engine 3 10-05-2002 03:23 PM
