Break Light Issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 07:33 AM
babailey's Avatar
Last journal entry: 1959 Short Bed Fleet Side
Break Light Issue
I have a brake light problem. The brake lights and the turn indicators all work fine when the lights are off. However, with the head lights on, the brake lights do not work at all.
This truck was rewired before I purchased it, so it has an aftermarket wiring harness in it and the original light switch is gone (been replaced with a typical two position switch). I suspect there is a wiring issue, anyone have any pointers or lessons learned?
Thanks!
Old 06-13-2010, 07:50 AM
poncho62's Avatar
Wiki Edits: 5
Most likely a ground issue.....Check all your grounds, especially the ones at the light sockets and headlight connections.
Old 06-13-2010, 09:47 AM
delawarebill's Avatar
whats a tipical 2 pos sw ??
if its the normal turn sig sw..?? then u really need to look into the wiring of the sw.. everything will pass through that sw. i hate those sw's so i just added a small set of amber sig lites and us a two position toggle sw... by-passing all that stuff.
Old 06-14-2010, 12:18 AM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
brake lights and tail lights are 2 different wires but share same ground. your switch is out of the equation. Being both sides are effected, look for their common ground.
break issue - stripped bleeder nipple KoTT Suspension - Brakes - Steering 9 07-09-2009 02:22 PM
Break lites don't work? 31 Ford A Electrical 13 08-23-2006 06:34 PM
Oil Weight Break In Again spanky36 Engine 2 06-18-2006 10:41 PM
break error light on 78 camaro? hcker2000 Suspension - Brakes - Steering 5 05-29-2006 08:09 PM
break light on..now what!? mrobby440 Suspension - Brakes - Steering 9 05-01-2006 01:30 AM
