break lights wired through oil pressure sending unit. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 02:55 PM
i have built my rat rod from alot of parts i have had kicking around and my break peddle like doesnt move at all before it engages, not that im complaining that the breaks are right their when i need them, but it makes it hard to do a normal break light switch when it doesnt move enough to operate it. my idea was to put a tee in the rear break line and put a two wire oil pressure sending unit out of an 1980 camaro in the tee and wire a relay to the power side of the break lights and have the relay operated by the oil pressure switch, would that work or am i missing something???
Old 02-04-2011, 04:24 PM
Go to NAPA and get a break switch already made for this.
Old 02-04-2011, 04:43 PM
anything in particular i should tell them to look it up by?
Old 02-04-2011, 05:39 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I'm not sure an oil pressure switch would hold up to that. I believe hydraulic brakes operate at substantially higher pressures than engine oil. There's no adjustment in your brake pedal linkage to give you a little bit of free play?
Old 02-04-2011, 06:50 PM
LATECH's Avatar
You will probably have trouble with the brakes locking up if you have no free play at the top of the brake pedal travel.If the compensating ports in the master cylinder are covered because the plunger is beyond them , it will cause the brakes to lock down after they get hot.
As the brakes heat up, so does the fluid, as it does it also expands. If the Compensating ports are blocked there is no where for the pressure to be go
so it applies the brake. Hence the need to compensate for expansion due to heat.Look in the master to see if they are blocked by the plunger seal. If they are not then disregard my post. Just thought you should know.
Old 02-04-2011, 07:21 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Jegs high performance sells a hydraulic brake light switch kit designed for your application.
You will need a double flaring tool to install a tee in the brake line.
An oil pressure switch WILL NOT handle the pressure. Hydraulic disc brake pressure can be up to 1000 PSI.
A relay is not required because the load of the brake light bulbs is small.
See the attached diagram that shows the brake light switch wired through the turn signal switch.
vicrod
Old 02-04-2011, 07:47 PM
LATECH's Avatar
Old fords (60 s era cars and trucks) used a switch like you are looking for. I believe it was a 1/8 pipe thread and had normally open contacts.
They use a similar looking switch on 90 ish and up fords it goes on the master cylinder as well like the 60 s one, But it is a normally closed switch I think and it is used for cruise control circuit cutoff,The were a bad Idea though as they are being recalled for a fire hazard, farout man.
Old 02-04-2011, 09:20 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
brakes
30 40 & 50 plymouth had single wire switches and double they screwed in line ! or into the master cylinder . Single wire is the easiest, hit the brake it grounds the lights. they are still available, hemmings. And the other gentleman is right if you do not have enough free travel it will lock up!! oil pressure sitch will not work, brake fluid breaks down the material and they leak out the top. check with a machine repair shop some mills ,laths etc. use switches like that and will stand up to brake fluid!
Old 02-05-2011, 09:56 PM
brake switch
summit has your switch,It screws into their [ adjustable proportioning valve#sum-g3910] and they sell the switch seperatly ! "ssbc braking rules" also sells this switch!
Old 02-06-2011, 01:51 AM
Wiki Edits: 31
Go to Napa and get a brake light switch for a 1965 AMC Rambler American. it'll cost about $12.. if you have a manual bendix ( usually Ford ) firewall mount M/C. you could get the master cyl for the same car. has a port on the bottom specifically for the switch. otherwise, just use a tee.. really all the switch is, is an oil preassure idiot light switch, normally open, closes with 6 PSI of preassure.. lots of cars use that type of switch.
Oil pressure sending unit jdl13 Engine 2 09-07-2008 10:17 PM
from dummy lights to guage. got new sending unit. one wire not 2 bullheimer Electrical 8 05-02-2006 06:25 PM
oil pressure sending unit fireguy Engine 5 02-11-2005 10:09 AM
Oil Pressure Sending Unit whsipersix167 Engine 2 11-13-2004 06:59 PM
Oil Pressure Sending Unit? TonyMac Engine 2 03-19-2004 06:41 AM
