Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - break line fitting leak
Old 03-23-2011, 11:44 PM
Deuce Deuce is offline
I suggest buying brake line with the ends already flared.
Use the factory flared end where you have been having a leak.
Flare the other end to length
Most likely the leak will disappear ... and if not ... the fitting is BAD ...
