break line fitting leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2011, 03:08 PM
3/16" line going into "t" fitting.
keeps leaking. i installed new line ( i flared it) twice now,ALL NEW.
i kept tighting , but still a slight leak.
what the heck.
i know all the rules, I THINK of flaring. maybe i don't.
i need HELP ! , any ideas or help would be apprciated .
thanks, roger
Old 03-23-2011, 03:39 PM
THERACER,
Double flares are tough to do. Cut the tubing with a very sharp tubing cutter. Then measure the amount of tube sticking out of the holder with the adaptor. Then install the adaptor into the tubing and make the first "inward" flare. Remove the adaptor and finish the second flare. When you finish look at the end to see if the tubing cracked. You might think of replacing the section of tubing.
Good Luck
Scholman
Retired
Old 03-23-2011, 03:59 PM
scholman,
i have done all that several times, still have leaky.
didnt appear to have cracked the flare.
do you have any tips on any other things to look for that i may be missing here?
its the short line going from the tee to the left front . i guess i will make another one. all the other seal up ok , go figure.
thanks, roger
Old 03-23-2011, 04:03 PM
make sure there is a few threads sticking out past the tee.
some flair nuts are longer than others and a short nut will bottom out on the nut flats
Old 03-23-2011, 04:10 PM
still got threads showing , thanks.
Old 03-23-2011, 07:34 PM
THERACER,
Only other thing to check is the Tee itself. Maybe the seat is dinged or damaged.
Is the leak coming from the thread area or from the tubing side of the nut?
You could try not flaring the second flare all the way down. So when you tighten the fitting, the flare will seat against the bottom of the "T" fitting and then be compressed to fit the seat inside the "T".
Good Luck
Scholman
Old 03-23-2011, 07:46 PM
scholman,
i believe it comming from around the threads.
i will try that next time around.
that may just do it.at least i hope.
thanks again, roger
Old 03-23-2011, 08:21 PM
302 Z28's Avatar
The cut on the tubing must be square, if it is off just a little the flare will be distorted and it will leak no matter how tight you get it. After you cut the tube chuck it up in your flare tool base where it just sticks up a little and see if it's square, if it's not dress it with a file until it is square.
Vince
Old 03-23-2011, 10:44 PM
I suggest buying brake line with the ends already flared.
Use the factory flared end where you have been having a leak.
Flare the other end to length
Most likely the leak will disappear ... and if not ... the fitting is BAD ...
Old 03-24-2011, 05:24 AM
goin to the auto store today and get a new line with fittings on the line and a new tee, and start over AGAIN .
this makes the 3rd time.
i will follow all tips from you guys, thanks.
problem is the brake fluid goes all over the place, makes a mess.
dont get it on any painted areas. i try to be neat.
roger
Old 03-24-2011, 06:29 AM
scholman, i checked this morning , the leak is from around the tube not the fitting threads. whats that tell me?
thanks, roger
Old 03-24-2011, 07:40 AM
willowbilly3's Avatar
Last journal entry: Body mods
I'd bet you have a bad T. With all of that stuff coming from China now, quality control isn't what it used to be. The plant I work at gets bolts from Fastenall. At least half of the bigger bolts are so rough the nut won't spin on with your fingers.
Old 03-24-2011, 11:16 AM
Last journal entry: Bringing home the 401 Nailhead
Check that T. Some Ts have flared ends and a 1/8" NPT in the middle for a brake switch. If that is the case it will never seal.
Old 03-24-2011, 12:25 PM
T-bucket23's Avatar
Wiki Edits: 26
If you have the original take a peek at it. Make sure the flare on the original is the same as what you are making. You didn't say what kind of vehicle but some use that bubble flare. There are also 2 different flaring angles, make sure you are using the proper tool. The flare on the line and the block need to match.
Standard is 45* AN is 37*
Chet
Old 03-24-2011, 04:33 PM
im using std. 45
i plumbed the whole car on total build.
decided to change the master for the cpp mcpv master and re-do front
lines.
just a dang fluk , i guess u would call it .
there has to be some simple thing im taking for granite.
all good advice and suggestions here, for sure.
what is the overlocked thing im missing? i'll get it this week end.
thanks , roger
banjo fitting leak Oldguy48 Suspension - Brakes - Steering 5 02-18-2011 06:41 PM
Help with -An fitting to hard line... obengston General Rodding Tech 16 11-23-2010 08:31 PM
200R4 line fitting sizes... S10xGN Transmission - Rearend 4 02-19-2009 05:14 AM
AN Fitting Leak nova69 Engine 3 06-04-2008 08:46 AM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 02:30 PM
