Nope.
Most modern gasoline multi-grades (ie 5w30, 10w30) don't have the right additive package containing zinc and /or phosphorous. Break 'Em in Easy ZDDP Additive Both articles recommend using a diesel-engine grade 15w40 (Shell Rotella T for example) and some GM "EOS" (Engine Oil Supplement). That's exactly what's in my 454 right now ... and I'm getting anxious to fire it up! |
5/30 should be OK. I just have this thing that I've used 10/30 Valvoline for ever and never had any problems so I stick with it.
Modern rings with the correct bore finish are not much of a concern. The cam is the major break in concern if it is not a roller. If you have a flat tappet cam make sure that you are using an oil that has zinc in it. 10/30 Valvoline VR1 or diesel oil Add a can of GM E.O.S. (engine oil suppliment)for break in. Joe Gibbs Lubricants has a break in oil now also. To check out some oil stuff look at this http://www.atis.net/oil_faq.html |
I go with Valvoline straight 30w with EOS from GM- I always run valoline in my cars and Rotella Synthetic Diesle in my bikes. And I will NEVER touch penzoil- after seeing the crap that build up from it I wouldn't put it in my nieghbor's lawnmower.
ive always had the best luck with pennzoil, anything else it burns oil, pennzoil was the cleanest also i had castrol for about 30,000 miles and it stained the motor black inside. ill probably use pennzoil, would the longlife diesel oil be what i use for break in? or straight weight because all straight weight pennzoil still have the Z7 additive. and could anyone tell me what is in the Z7 additive package?
This link may help
New cam break in info |
thats funny right there I don't care who you are ! Plus I feel the same about penzoil Mustangsaly |
I'd suggest readking that other thread.
Rotella T is now "CJ4" as of July 06. I've gotta check to see what the stuff I put in was... Maybe I'll order a skid of "CI4" oil and stockpile it. |
| Engine break in oil | 63Fair | Hotrodding Basics | 11 | 12-03-2011 09:51 PM |
| Oil Pressure questions | RObs71Nova | Engine | 22 | 05-02-2009 01:45 AM |
| Synthetic Motor Oil In 454 Rebuild | leejoy | Engine | 36 | 11-20-2006 02:34 PM |
| oil leak | rb8179 | Engine | 11 | 06-03-2006 03:07 AM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
