-   -   Break-in oil (http://www.hotrodders.com/forum/break-oil-183406.html)
goldenbullet44 08-27-2010 12:44 AM
Break-in oil
What kind of break in oil should i use with the zinc additive for breaking my camshaft in? I'm running a lunati barebones cam
Thinking about http://www.oreillyauto.com/site/c/de...0432&ppt=C0162
30 weight oil
techinspector1 08-27-2010 01:54 AM
Here is a list of mistakes that will result in a pooched flat tappet cam.....please read through several times, then ask questions if you don't understand. Failure to understand everything written here could result in you having to pull the motor, disassemble it, clean it thoroughly to remove all the shrapnel from pooched lobes and lifters, re-purchase of cam and lifters, reassembly of the motor with all new gaskets and then holding your breath that it won't happen again.
http://www.crankshaftcoalition.com/w...t_tappet_tools
BEST PLAN: ROLLER TAPPET CAM AND LIFTERS.
sqzbox 08-27-2010 07:28 AM
Summit sells a high concentrate ZDDP oil and Valvoline racing oil has it also.
You can get the Valvoline at Napa. Good luck! :D
Techinspector, how's the heat out there? Nice and warm? :cool:
Blownchevelle68 08-27-2010 03:35 PM
Ditto....used Valvoline VR1 after initially breaking engine in with Royal Purple Break in oil and a bottle of Comp Cams additive-along with the normal cam lube of course....
bigdog7373 08-27-2010 05:44 PM
I just went into advance auto parts and got the only kind of break in oil they have. I don't remember the name but i haven't had any problems so far so it worked.
Duntov 08-28-2010 08:39 AM
Originally Posted by F-BIRD'88
http://www.molyslip.com/ Time tested proven engine anti-wear technology.
Impressive reviews. I'd never heard of in until now.
