Break-in oil
What kind of break in oil should i use with the zinc additive for breaking my camshaft in? I'm running a lunati barebones cam
Thinking about http://www.oreillyauto.com/site/c/de...0432&ppt=C0162 30 weight oil |
Here is a list of mistakes that will result in a pooched flat tappet cam.....please read through several times, then ask questions if you don't understand. Failure to understand everything written here could result in you having to pull the motor, disassemble it, clean it thoroughly to remove all the shrapnel from pooched lobes and lifters, re-purchase of cam and lifters, reassembly of the motor with all new gaskets and then holding your breath that it won't happen again.
http://www.crankshaftcoalition.com/w...t_tappet_tools BEST PLAN: ROLLER TAPPET CAM AND LIFTERS. |
Ditto....used Valvoline VR1 after initially breaking engine in with Royal Purple Break in oil and a bottle of Comp Cams additive-along with the normal cam lube of course.... |
http://www.molyslip.com/ Time tested proven engine anti-wear technology.
| Chevy 6.5 Diesel has no oil pressure again!!! | dorksrock | Engine | 12 | 09-02-2012 08:51 PM |
| Engine break in oil | 63Fair | Hotrodding Basics | 11 | 12-03-2011 09:51 PM |
| Smoke'n motor | Red neck blazer | Engine | 25 | 06-09-2009 02:32 PM |
| Synthetic Motor Oil In 454 Rebuild | leejoy | Engine | 36 | 11-20-2006 02:34 PM |
| Jiffy lube rant: what would you do? | killerformula | Hotrodders' Lounge | 35 | 02-16-2006 06:07 PM |
