What are you working on power brakes ?
Cole |
Don't know why i ask that last question i must be loosing it. There is a relief valve in the sealing ring at the plunger input failing to let in fresh air. Sounds like new booster time to me.Cole |
Cole that wasn't a Dumb question.
It could also be the inside of the Brake hoses collapsing. It's happened to me several times. The Master Cyl. pressure will force fluid thru the lines/hoses but there's no pressure to pull the fluid back. Can cause a slow Pedal return or locked brakes. Had an old 71 Dart w/Manual Drum/Drum brakes, press the pedal 1 time and both front brakes would be locked for an Hr. or more. Of course I started at the Master Cyl. then Wheel Cly. and finally hoses. My Dad said "Hoses" when I asked before starting, I was young & dumb but, was thinking how could both hoses do this at the same time.
pedal was slow before and after
Could it be the peddle hinge gummed up under the dash; interference of some sort.
Is the peddle moving slowly look for that, you talk about the brake lights no going out, but the brake are releasing. The other option is the switch itself being slow to reset. |
| How Much Pedal Travel | redsdad | Suspension - Brakes - Steering | 5 | 08-29-2011 05:24 PM |
| Hydraulic Clutch Troubleshooting help? | tylerwerrin | Hotrodding Basics | 20 | 09-09-2010 09:16 AM |
| No Pedal Free Fall | joeford | Suspension - Brakes - Steering | 4 | 02-16-2010 12:04 AM |
| Slow Dance | Gr8 '48 bow tie | Off-Topic | 4 | 02-19-2006 11:24 PM |
| Heavy Brake Pedal Question | bluesman123 | Suspension - Brakes - Steering | 0 | 05-23-2004 10:41 AM |
