Break peddle question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2010, 06:50 PM
Localboy808's Avatar
Hi guys. Guess this should be the right spot for this question. I'm building a 67 El Camino. Stock it came with a 3 on the tree column shift manual. I'm going with an automatic. My question is does anyone know where I can find the replacement break pedal assembly? I removed the clutch/break pedal. What is the best way to handle this situation? While I'm on the subject. Can I use the column shifter to work a th350? Any help would be greatly appreciated!
Thanks, Scott
Old 12-30-2010, 06:55 PM
bigdog7373's Avatar
Of course it's fast
Could you remove the clutch pedal from the assembly and keep the brake? If it were me though i would keep the column shifter. They're pretty hard to find nowadays.
Old 12-30-2010, 06:59 PM
I might be able to do that. It's just that the non clutch version cars came with a bigger break peddle. And I would love to keep it a column shift auto if I could. That way I don't have to cut the floor. I will if I have to though. . I'm hoping to hear from someone that has gone through this.
Old 12-30-2010, 07:10 PM
bigdog7373's Avatar
Of course it's fast
I don't have any experience with column shifters. Cutting the floor isn't too hard though and if you're using bucket seats then you could use a nice b&m shifter or even put a console in the middle with a nice ratchet sifter. Just something to think about.
Old 12-30-2010, 07:20 PM
That's a good point you brought up. I'm using the original bench seat. Will that seat allow enough room for a floor shifter?! I had my eye and almost picked up a B&M shifter today. I held off cause I really would like to make the column shifter work.
Old 12-30-2010, 07:25 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
no, you can not reuse the column shifter from your three speed for a auto
you will need a different column
i have just removed the pin that hold the shift handle to the column and put it on the floor with a aftermarket floor shifter
and i just removed the clutch pedal and l just used the smaller brake pedal
Old 12-30-2010, 07:32 PM
that's kinda what I was thinking I would end up having to do. Now is there enough room for a floor shifter and bench seat?
Old 12-30-2010, 07:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have been doing this for years, Leave the clutch pedal on and put it under the carpet in case you ever decide to go back with a manual trans. That what i did with the clutch pedal in my camaro it's under the carpet if i need it down the road.JMO
And with the right shifter you will have room with the bench seat. JMO
Cole
Old 12-30-2010, 09:21 PM
ericnova72's Avatar
More for Less Racer
If you want the wider brake pedal you will likely have to get it from a wrecking/salvage yard from another 64-72 A-body, I don't believe any of the reproduction parts houses have the auto trans brake pedal, just the clutch/ brake pedal combo because that is the more common switch(a lot more people switching auto trans to manual than the other way around like you want to do). You could check repro suppliers, it might be out there, and some repro parts suppliers also run salvage operations for the same car they sell repro parts for, you just have to ask.
Steering column would have to be changed for an automatic column, they are different.
Old 12-30-2010, 09:42 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Check on a web site called "Team Chevelle". I'm sure you can get what ever you need to make the conversion with stock parts over there.
Old 12-30-2010, 10:46 PM
Thank you for all the great advice guys! I appriciate it!
Scott
Cam break in Oil question? truckboy61 Engine 12 10-10-2010 01:57 AM
brake peddle johnccarlson Suspension - Brakes - Steering 1 04-06-2010 06:14 PM
master cylender brake peddle very soft bel52air Hotrodding Basics 4 12-30-2007 08:52 PM
gas peddle spring irwin goldstein Engine 1 08-28-2006 10:57 AM
Cam Break in question... Mike_82 Engine 5 01-02-2004 12:28 AM
