Break problem
Have a 56 F100 disk front drum rear, built for my wife, problem is loosing break fluid and have pedal when engine off but when running goes to floor, also can't find a leak has a remote resover.
If you are loosing fluid you have a leak. I would pull teh rear drums and check the cylinders if you cant find anything else.
Artificial Intelligence is no match for Natural Stupidity Chet |
have a look on the inside of rear tyres..fluid will leak out the rear of the drum if cylinders are shoot..pretty common for cylinders to let go.check all lines and connections.if your peddle is going flat on startup you are pulling in mayor air somewhere.i had 2 bad wheel cylinders and still had brakes.
Sounds like a bad master cylinder to me
Ontario Rodders |
You might find your leak by loosening the MC from the booster.
| Break in --- oops, break up | Irelands child | Off-Topic | 3 | 03-22-2011 10:55 PM |
| Dyno Break In Versus Normal Break In | hoops | Hotrodding Basics | 4 | 10-01-2010 04:41 PM |
| Synthetic for break in? What weight ? (engine and cam break in that is) | sizemoremk | Engine | 5 | 08-14-2003 04:50 AM |
| I need a break | 78 monte | Hotrodders' Lounge | 6 | 03-05-2003 01:13 PM |
