Breakin Down a Tire - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2008, 07:39 PM
Breakin Down a Tire
anyone know of any tools or somethin similar to break down a tire? we blew a tire the other day on the 35 horse Massey we got and we ended up takin the wheel and tire to town to get it broke down. thanks
Old 03-03-2008, 07:48 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You can get a bead breaker from Harbor Freight.
Old 03-03-2008, 08:01 PM
31 five window
Last journal entry: grill and rear end
Put a 2X6 like a ramp and drive a heavy vehicle up until the bead breaks loose. You may have to do it in several places if tire is stuck or rusted to rim.Go to NAPA and buy 2 tire irons to peel it off after breaking.
Old 03-03-2008, 08:07 PM
Well we drove a vehicle onto the tire but it wasn't a very heavy one....1991 Toyota Pickup 4 banger 5 speed with big Timberline L/T's on it....we rotated the tire a few times and tried to use a tire iron on it but it just wouldn't break down
re:breakin down a tire
Hi did you get the enjoyment of moving it around with the calcuim in it? DIGGING END OF PICK AXE, swing away! TROY
Old 03-03-2008, 08:10 PM
haha idk about all that...that wheel is pretty damn rusty...we're gonna have to do some patch up work around the valve stem cause it rusted through if that tells ya anything.....prolly the stock wheel from 1954 lol
Old 03-03-2008, 08:17 PM
Re: Breakin Down Atire
Hi ya l thought you would like that, l've been there,thank god for having more than l front end loader, its to bad you lost the caluim($) and them rims are hard to get anymore, so ya weldings the best answer, but ya l have broke down the bead with a pick axe, put l'm not 20 anymore so l pay! TROY
Old 03-03-2008, 09:11 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
you could but the tire under a truck and then put a jack between the tire and the truck frame.
Old 03-03-2008, 09:35 PM
sweat
There is a tool called a bead hammer,it's a sledge on one side and a large smooth slightly curved chisel head on the other.I have had good luck breaking down old rusty truck and tractor beads with mine.You have to be pretty accurate with your swings because your objective is to hit exactly between the rim and the bead.The problem is if you miss ya got another spot in your rim to repair.should you go this way the best way is to start real easy until you get your accuracy down then give it h***.Just keep rotating and hitting it will eventually break the bead,or your enthusiasm.The pick axe is a little to light for truck or tractor old stuff.Plus you would have to grind the edge down to avoid some real damage.
Old 03-04-2008, 03:31 PM
Last journal entry: frame build
With a tire hammer and some dish soap, you can breakdown just about any tire you can lay flat. Somtimes it is better to use a small sledge to drive the beadbreaker in cause if you slip and hit the rim instead of the tire, it probably going to give your shin a raspberry you won;t forget for a long time.. tip side to side a couple times to work the soap down and work your way around. Seldom have to go over half way around before it gives.Or maybe just take it to a tire shop.
Old 03-10-2008, 10:01 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Oh, those rims are not too hard to get.
Got a mason's chisel or some splitting wedges or the end of a leaf spring? Drive 'em in until they just 'clink' solid against the wheel, move over about 6 inches and do it again. Repeat all the way around the bead. Won't look like you're accomplishing a thing until you get all the way around. Mix brake fluid and water and pour that in the little gap you just started. Continue around the rim, angling downward as much as the gap allows. By the end of the 2nd trip around the rim, you should see quite a bit of gap. Keep going and it will break down.
Builds character.
Used to change truck tires and tractor tires as a part-time job after school, too many decades ago. We had what amounted to long slide hammers with dull chisel points for breaking those beads down -- heavy pipe with a solid rod through it. Not certain they're still made today, but you could make one with a 4 ft length of 2" pipe, an axle and a 3" mason's chisel.
[Edited to add:]
Found one!
Ken-tool 35926 Heavy Duty Impact Bead Breaker
Looks like it has been improved slightly:
The 35926 has exclusive spring action design to reduce user fatigue associated with slide hammer kickback. 5" in length, 80" extended. Weight: 23 lbs.
Didn't have springs or that comfy-looking handle when I had to use similar things. I was swindled!
Old 03-11-2008, 10:22 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Back when I was under 10 years old, my dad had a rear tire go flat on his 706 IH. He used a chain, a hy-lift jack and a ton o' cursing to break the bead. Just don't ask him about the starting fluid and a match to re-seat it....
In a while, Chet.
Old 03-21-2008, 09:40 PM
If you have a tire rusted to the rim use heat. Heat the rim around the bead area with a torch. Stop heating when the tire starts to smoke.Follow up with one of the above methods.
Old 03-21-2008, 10:12 PM
schnitz's Avatar
Wiki Edits: 54
I'm not going to completely back that one up. I used to routinely see area farmers use starting fluid as a "boost"to get farm wagon/ tractor tires to seat on the bead. I'm not sure I'd want to test the big bang theory....
In a while, Chet.
Old 03-28-2008, 06:45 PM
leldai73's Avatar
Its just metal,you're the boss
for tractor, skidder and truck tires we use a tire hammer and a few tires irons, one custom made unit thats 5 feet long...whats a tire hammer you ask? well, here ya go
to re-seat the bead we use a tool called a cheetah . its like a really short air cannon.
Canadian Tire wrecks engine 4 Jaw Chuck Hotrodders' Lounge 31 12-09-2010 11:39 PM
I Think Someone Doesn't Like Me. (3rd tire problem) Ghetto Jet Hotrodders' Lounge 12 05-22-2009 06:15 AM
Not a hot rod tire question but it could be old-bill-t Suspension - Brakes - Steering 13 03-04-2008 10:29 PM
A Tire Happenings Synopsis hobbytires General Rodding Tech 21 12-03-2007 06:18 PM
How to determine effective tire diameter sabino56 Transmission - Rearend 19 10-27-2006 10:19 PM
