Breakin the motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2005, 12:36 AM
juiced66malibu's Avatar
Breakin the motor
How many miles in a motor is considered broken-in? I have zero miles on the bottom-end. I am thinking of dynoing my new bottom-end motor next month.
Old 10-26-2005, 07:47 AM
brainsboy's Avatar
brains
I'm sure you will get some different answers, not to comment on break in time, I will add in that I have had several motors go bad due to bearing failure, as far as having any possible bearing problem, it seems that they need 500-700 miles before you hear any noise.
Ben
Old 10-26-2005, 10:13 AM
engine break in
put it on the dyno when the temp. is up to normal run it up to 60% of hp for 10 min then go for broke . if the job was corectly dun no problem if not it will fly apart. also when finished cut open the filter, expect some small particals. check again in 500 miles.should be no particles if engine properly assembled
Old 10-26-2005, 10:59 AM
johnsongrass1's Avatar
Race it, Don't rice it!
That's what I do, run for 20 min for the cam using Rotunda 10W40 tractor oil and then dump it. Add mobil 1 full syn. After that, hammer it.
Nothing about breakin will save anything if it's not assembled correctly.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
Need Help Trying To Get Motor Dialed In 70SPORT Engine 7 01-14-2006 01:27 AM
New guy here with questions about motor build AustinClassic Engine 3 05-26-2004 04:40 PM
New motor in!! won't start!! Trav Engine 20 05-06-2004 11:54 AM
I need a new motor in my vw. 72superbug Engine 14 08-21-2003 02:55 PM
