breakin/start-up oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2012, 05:24 PM
What is the best Engine/Break-In/Start-Up oil? What is the best Additive? Is one brand line clearly better, or all they all pretty much the same? Does cost make any difference? Iv'e got 6qts of Pennzoil 10w-40 in there now. Shud I drain this, add the additive(s) then pour the oil back in?...............fb396
Old 06-14-2012, 06:03 PM
Richiehd's Avatar
JS-70
What are you running? Flat tappet cam is the issue. ZDDP additive added to oil for cam break in.
Old 06-14-2012, 07:04 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
For flat tappet cams, I always use Valvoline VR1 Racing Oil plus ZDDP additive. Roller cams are not an issue, use any good quality oil.
Old 06-15-2012, 02:44 PM
fb396 oil
Nothing special... just a regular CompCams Hydraulic Cam.....dur.236..lope sep. 110...lift.556/556..in a BBC
Old 06-15-2012, 03:34 PM
S10 Racer's Avatar
You will need an oil such as VR1 and then add more ZDDP or buy the Brad Penn brand.
Old 06-15-2012, 08:02 PM
6426yy's Avatar
I use the zddp and cheap oil with worn our stock valve springs. then switch springs after break in.
Old 06-15-2012, 10:17 PM
I'm no expert, but I was told by a former instructor and race car builder , , use the Zinc additive ( for the cam ), then any GOOD oil after that, I asked about the mile milage Valvoline 10 /40 that I had on hand, he said ''fine ''. And I think it's also synthetic
sbc first start break in oil southshore30 Engine 8 04-14-2012 03:17 AM
350 Chevy Breakin Oil Consumption ??? 40forddgc Engine 3 05-02-2010 10:36 AM
What oil manufacturer for start up?? sexypizzaman Engine 7 05-09-2008 09:32 AM
Change Oil After Initial Start? nova69 Engine 3 04-23-2008 06:24 PM
what oil for start up and break-in? BanditT/A Engine 49 03-11-2004 05:49 PM
