Breakin for warmed over engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2012, 11:42 AM
JMSTOY's Avatar
Last journal entry: The death of Blue
Wiki Edits: 17
HI,
Did a very quick down and dirty warmover for my 350 sbc. It was in great running shape when I pulled it from the donor truck. Took off the intake, heads, all accessories (water pump, fuel pump, etc), and oil pan. Replaced the oil pump, water pump, alt, fuel pump with new stuff, cleaned the heads and intake up and painted them, and put it back together. Like I said, quick down and dirty due to money, for now. Question is, break in. Since cam and pistons and mostly all the internals were not touched, do I need to do a full break in proceedure? Or a modified watered down version? What would you guys reccomend? You never steered my wrong yet, thanks!
Zak
Old 02-13-2012, 11:48 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by JMSTOY
HI,
Zak
No need for a full break in procedure. IMHO
The main thing i would do from what you said you have done to it,
i would at least re-prime the engine and make sure everything is oiling good before start up since you did replace the oil-pump. Everything else should be fine.IMHO-JMO
Cole
Old 02-13-2012, 12:03 PM
JMSTOY's Avatar
Wiki Edits: 17
Cole
kinda what i figured. What about break in additive, is it a waste for my situation? I have a nice oiler, used a old distributer, ripped it down and ground off the bottom gear. Hooks up to a drill, works beautiful, so repriming is no problem. Thanks!
Old 02-13-2012, 12:37 PM
eloc431962's Avatar
Wiki Edits: 37
I really wouldn't worry about putting any break in additive in it myself the engine is already broke in . JMO
Cole
Old 02-13-2012, 12:44 PM
JMSTOY's Avatar
Wiki Edits: 17
Cole
ok, thanks!
Old 02-14-2012, 04:47 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Breaking in an engine mean you are mainly seating the rings to the bores, and if you have a NEW flat tappet cam, seating the lifters to the cam, that's about it , but since you didn't mess with any of that their is no need.
Old 02-14-2012, 07:32 AM
Hope you put the lifters all back into the same holes they came out of...
Old 02-14-2012, 11:19 AM
JMSTOY's Avatar
Wiki Edits: 17
Yes I did. I did research this project a lot before taking it on. I took 300 pictures of dissasembling the engine, and individually ziplock bagged each piece or groups of bolts and labeled it. It may be overkill, but I wanted my first rebuild to go smooth. So far, it is working out really well.
Old 02-14-2012, 03:44 PM
327NUT's Avatar
There's no such thing as overkill when you're re-using the orig. cam/lifters. It's like ...measure twice and cut once. You did the right thing.
Old 02-14-2012, 04:15 PM
eloc431962's Avatar
Wiki Edits: 37
Just were did the "OP" state that he removed the cam and lifters i must have missed that somehow.
Cole
Engine/Cam Breakin jmichaelre Engine 59 10-29-2009 02:07 PM
Problem Re-Starting engine after its warmed up! MIPLAYSTATION Engine 3 08-09-2008 09:02 PM
F1 Engine Breakin Shelby1 Engine 1 04-17-2008 06:34 AM
New engine breakin proceedure... smac Engine 3 11-20-2005 05:35 PM
question about engine breakin??? Robbie Engine 3 01-13-2004 03:47 PM
