Breaking in a SBC with diesel Oil?
I have read a few articles on this and would like to know what some of the builders on here think. I have also read that because of the conditioners that this could produce sludge if not evacuated properly. I'm close to having all my parts and will be finishing it soon. Any thoughts on best cam lube and engine lube for Assembly. I have a Lunati cam and I will probably use their lube like recommended. I look forward to reading your responses to the diesel oil break in.
Just use good quality oil and add a can of THIS stuff.
Using a good quality oil and a zddp additive was what I had initially thought, their are several zddp additives on the market I just wanted to know if others have done this and what their thoughts on it were.
so should I use my 550 lift springs or should i get a smaller set for the break in.
Would Z-MAX be a good additive to add to your oil after break in?
No auto mfrs I am aware of use a flat tappet cam today, or, any of the last several years. One only need look at the Comp Cams site's ' Flat Tappet Tech Bulletin' for further info in this regard. Oil that is... Also see this |
| Chevy 6.5 Diesel has no oil pressure again!!! | dorksrock | Engine | 12 | 09-02-2012 08:51 PM |
| more on ticking sbc -- oil pressure | mhamilton | Engine | 3 | 12-26-2006 07:24 AM |
| Excessive oil under valve covers in SBC? | TVR383 | Engine | 13 | 11-21-2005 12:48 AM |
| Oil Temperature and oil types (long) | TurboS10 | Engine | 36 | 03-01-2005 01:51 PM |
| SBC oil | Camaro76 | Engine | 7 | 02-18-2003 01:54 AM |
