You could run 1 Line from Valve Cover connected to the Carb Breather so it gets filter air.
1 Line from other Valve Cover/PCV to Catch Can to atmosphere or back to Intake or bottom of Carb. I had a link for a Homemade Catch Can but, it doesn't work anymore. Back to Google. Here's one>> http://www.condensator.com/ Several ideas here> http://www.google.com/images?hl=en&q...A&ved=0CGEQsAQ An old A/C Drier could be used to Fab one up.
I run a system similar to what you are wanting to do on my 82 Z-28 with a 406. I run two breathers that are actually oval billet style from Summit Racing. I took the bottom plate out and sealed the holes up that were in the bottom for the breather to vent. Then I drilled a 1/2" hole and tapped it with an NPT pipe tap to thread in some an fittings along with some 1/2" push lock hose that goes to one catch breather can that I mount to my radiator support with the same 1/2" an fittings to connect it all. There is a breather that is connected to the top of the breather can for venting. I have no mess on my valve covers anymore. The breather can has a drain valve on the bottom for emptying out. I run no pcv and have had no issues since I only drive this during the summer season and put no more than 1000-1300 miles on the car during the season.
I have the car somewhat torn apart getting ready for the season but I will try to get some pics when I get it back together so you can see what I have. It works great for me and it was not too bad, cost wise, to build it. I bought the breather can from a tuner shop because it was a unit that was the size I was looking for since my engine compartment doesn't have alot of room. I believe the breather can was something like 40.00 shipped from overseas. Everything else came from Summit Racing.
Check out these Corvette pics at Hot Rod, the guy is running two remote "puke" tanks from the valve covers.
Also check out the attachment, from May Hot Rod, one "puke" tank. |
Here's the updated pics of the setup I am using on my car for v8hed. I really like this since it has the drain **** in the bottom that I can slip a rubber hose onto and run below to empty if need be. I used Summits breather, twist-tite hose in size -8 with their twist-tite fittings. I drilled the breather tank for 1/2" npt fittings with -8 male ends then connected the -8 female connectors and hose to that. Hope this helps you out in decision.
Chet |
Thanks Chet... looks good
I think I'll probably run something similar, but may use 2 separate tanks... one for PCV, which will vent into the PCV port on the carb and one tank for the breather on the other valve cover... that tank will vent to atmosphere. Then again, if the valve cover for the breather is baffled, it shouldn't need a tank as it shouldn't draw any significant oil, so maybe a regular push-in breather would work OK and I can just use a catch can for the PCV. |
I tried the pcv in my valve covers with a breather in the oposite cover, I just didn't like the contaminated vapors burning into my carb and I really didn't like the vapors and film on the cover from the breather. I never thought of tieing the pcv into a tank first then to the carb. I like the way this setup has worked for me and I did consider two tanks, but room is at a premium so I needed to make this work as efficiently as possible. I know when I drive my car, I like to hammer it through gears whenever I can as my friends can would say. I do enjoy the drive...
| PCV Oil Catch Can? | kyle86 | Engine | 7 | 07-20-2010 10:14 PM |
| Another 283 - Questions about the Setup | nnmnm | Engine | 5 | 05-24-2007 01:46 AM |
| 4 bar setup on 32 Ford - have questions | heyjude076 | Suspension - Brakes - Steering | 6 | 12-30-2006 05:37 AM |
| 383 Stroker setup questions | speedingpenguin | Engine | 22 | 08-08-2006 12:29 PM |
| building an oil catch can ? design questions | lowROLLERchevy | Engine | 2 | 03-20-2006 11:13 AM |
