Briggs Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 07:09 PM
Last journal entry: Project "Black Sunshine" Started
Briggs Problems
OK, I have an older 5hp Briggs on a go kart of mine. The motor has good compression and stuff and we just put on another coil on from a newer 5hp Briggs without points. But today we put on the coil and drove it around for a while. Then a friend was on It and it made a loud noise and sheered a flywheel key. So we replaced it and it happened again but messed up the crank this time but we have no idea why it sheered the flywheel key. If anyone knows whats happening please let me know so I can correct it before I put in a new crank.
Old 03-19-2006, 10:18 PM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I don't have very good luck with Briggs engines, they tend to blow up on me. I get along better with Kohler or Tecumseh.
Old 03-20-2006, 08:35 AM
you might find some help here..... http://www.perr.com/forum/
Old 03-20-2006, 11:46 AM
Dutchman's Avatar
Old Salt
Can't tell you the reason, however, if you know a good machinist, they can put in a new keyway for both your crank and wheel (180% from old ones). I had it done at a tech school, worked great and never quit. Didn't cost me anything, I figured if it became screwed up, nothing lost.
Dutch
Old 03-21-2006, 03:23 PM
Mustangsaly's Avatar
know any jr. dragsters ? they make 5hp briggs screws I found a original 73 lil indian chopper mini bike my son & I built with a briggs raptor 3 race engine , added a tillitson carb & a 2 stage header, comps cam, ect. it fls or buy a great go cart race engine right outa the box. http://www.briggsracing.com/display/...p?docid=101243
http://www.4cycle.com/bbs/
read learn lota fun.
Mustangsaly
Old 03-21-2006, 04:22 PM
Wiki Edits: 31
if it's a 5 horse Briggs industrial, they have a roller bearing on the end of the crank, it could be hanging up , pull off the crank cover and check it. could be a techumse flywheel key also, they will work but there a trapezoid rather than square, and can sheer when there not supposto
Old 03-22-2006, 01:35 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
The swap to a Magnatron coil should work with no problems, so something is
binding up, or out of time. If the starter clutch (flywheel nut) is not tightened
down on the F/W enough it will slip on the taper, shearing the key. The key is soft, and is
supposed to shear if something is wrong with the engine to prevent more damage. The key only positions the flywheel at install, being tight on the taper is what keeps it from slipping.
Old 03-23-2006, 03:47 PM
Marcel
Last journal entry: Choo-choo town
Briggs Problems
If he had a soft key, why did it mess up the crank and flywheel. I had a 14 hp. briggs that kept shearing keys, I put a electric impact on it and tighted till it stopped turning and it quit. lol
Old 03-24-2006, 12:12 PM
FASTCHEVY's Avatar
Usually when the key is sheared, like if you hit a stump with a lawn mower, it will only shear it slightly because the flywheel is so tight. But if the flywheel is loose it will roll over the soft key and eventually roll over the groove on the
crank.
'97 Sable electrical & washer pump problems Gearhead forever Electrical 9 12-03-2005 05:31 PM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 06:56 AM
SBC 350 Crank Balancer Problems bjam2 Engine 8 05-04-2004 07:36 PM
Transmission Problems marcomccaine Transmission - Rearend 4 02-17-2004 04:26 PM
Pinto engine problems Transit_Man Engine 1 07-11-2003 06:27 PM
