Brighter headlamps - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2003, 06:51 AM
xtreme off-road's Avatar
Cool Brighter headlamps
Here is a small circuit to make your headlights brighter. Whith this in place the lights get power directly from the battery, instead of going thru all the factory wiring, and are much brighter. The diode is optional. It just makes your low-beams stay on when your hi-beams are on and you get even more light.
I've done this to many vehicules and the differance is amazing.
Old 02-03-2003, 07:04 AM
Post
xtreme off-road
Thanks for the infor I have used the same set up for lights on snowplow trucks for years.But never thought to use it for my normal driving lights or it even having an effect on them. Will give it a try .
Old 02-03-2003, 07:18 AM
Post
Forgot to explain (for the electricaly challenged ), you have to cut the wires leaving the firewall, going to the headlamps, and put this in the circuit.
