Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bringing the power steering pulley up one groove.
Old 09-08-2012, 09:29 AM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Originally Posted by joe_padavano View Post
Why are you worried about this? Millions of cars have been built without power steering and with only one belt on the water pump. Don't waste your time.
If you're worried about a side load on the water pump bearing, don't. Unless the two belts pull in EXACTLY opposite directions (with they will not), there is ALWAYS a side load on the water pump bearing.
Alright well... okay... I would def. rather not worry about it if i dont have to. I just measured and there is 2" of belt making contact on the pulley, as long as thats okay..
