If you're worried about a side load on the water pump bearing, don't. Unless the two belts pull in EXACTLY opposite directions (with they will not), there is ALWAYS a side load on the water pump bearing. |
| The Following User Says Thank You to joe_padavano For This Useful Post: | ||
0trbo4myCHEVUICK (09-08-2012) | ||
Alright well... okay... I would def. rather not worry about it if i dont have to. I just measured and there is 2" of belt making contact on the pulley, as long as thats okay.. |
Up until serpentine belt systems came to be , probably 95% of cars had belt setups that only contacted maybe 1/4 or less of the pulley O.D. , works just fine ! Just don't overtighten your belt!!
dave |
| The Following User Says Thank You to 2old2fast For This Useful Post: | ||
My '75 SBC with HD cooling had the type of pulleys you are looking for. The water pump has a two groove pulley, and with HD cooling the PS belt goes over both the crankshaft and the water pump. When I look up the parts number for a PS belt there are two options, a short and a long belt. Both will work, but only the long one routes around the water pump.
I am running the long PS belt because it keeps the water pump running even if I break the alternator belt. I've had the alternator belt break once on the highway when I was running the short PS belt and it only took about five seconds for the water temp to get into the red once the water pump and fan stopped turning. Bruce |
Just carry an extra belt. |
| Power Steering Pulley, SBC | Sinister | Engine | 2 | 06-23-2010 07:10 PM |
| GM type 2 power steering pulley | b50bsa | Introduce Yourself | 1 | 12-07-2004 09:18 PM |
| GM type 2 power steering pulley | b50bsa | Suspension - Brakes - Steering | 3 | 11-28-2004 08:09 AM |
| Power steering pump pulley | Ktaves1971 | Engine | 1 | 05-18-2004 09:47 PM |
| power steering pulley | warlok | Engine | 3 | 02-11-2004 08:50 AM |
