Bristle or coating removal discs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 11:15 AM
Gearhead forever's Avatar
I'm in the process of removing paint (Factory coat & secondary re-paint) to bare metal on my project. My random orbit sander will surely wear out before all the paint is gone...
Can I safely take the majority of paint off with a bristle disc or 3M coating removal disc on my 4 1/2" grinder then finish up with the orbital? The repaint (Color & high build primer??) is really thick and much softer than the factory coat.
Old 10-02-2006, 12:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Yup..just quit with the grinder before you eat any metal and use your DA to finish up..I use a 7" grinder..a 41/2' grinder and a die grinder with 2" rolocs for paint removal..gets just about every where with just a small bit left for the sandblaster..
Sam
Old 10-02-2006, 02:36 PM
Thanks much...
Bristle Discs 35WINDOW Body - Exterior 9 09-27-2006 02:53 PM
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 06:10 PM
tough transplant - discs for miniature rod grouch Suspension - Brakes - Steering 16 05-16-2005 09:14 PM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 9 10-09-2004 12:45 PM
Bolt coating? 77cad Body - Exterior 2 03-24-2003 12:00 AM
