bristle disc - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2006, 10:10 AM
Ranchero_65's Avatar
bristle disc
Anyone here use these and have a opinion of them ? The reasion I asked is in some places I have been using small wire brushes on my die grinder but thought I'd try some of the bristle disc . I got some 80 grit 2 inches 3M and they worked so so seemed like the bristles would come off very easy. Also thought maybe 80 grit was to lite so I got some 50 grit ones but they were not 3M they sucked big time leaving a rubber residue so to heck with those and back to the wire brishes I went . I have some 50 grit 3M disc comming but we'll see. Just thought I'd ask if anyone else has used them and what there thoughts are..
Take Care
Earl
Old 07-04-2006, 10:50 AM
BarryK's Avatar
I use the so-called roloc disc's all the time in both 3M, Sia or Indasa but I use the 3" and only 24 grit and never have had a problem like your having.
I did try the 2" 50 grit in Norton once and they seem to wear out real quick.
Never used again and still have 3/4 of a box left.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Shrinking Disc, first time used dwhitt Body - Exterior 1 06-08-2005 07:54 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
