"Britains Fastest Van" - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-18-2011, 11:43 PM
malc's Avatar
Born To Be Mild
Originally Posted by 66GMC
Right, does Canada till use these weight terms ?
  #17 (permalink)
Old 09-19-2011, 03:12 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Even with all the metric BS up here, we still buy steel by the pound and CWT.
  #18 (permalink)
Old 09-19-2011, 10:22 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I honestly don't recall the last time that I've heard, much less, used that term.
I suspect that it was back in the 60's or 70's ... probably used in the context of grain or cattle in market reports. (Dad managed a rural grain elevator back in those days.)
  #19 (permalink)
Old 09-19-2011, 12:54 PM
malc's Avatar
Born To Be Mild
Wondering if 5CWT´s van is that weight or that is the weight it would have been designed to carry.
  #20 (permalink)
Old 09-19-2011, 01:45 PM
5 CWT's Avatar
cwt
there are 20 cwt"s in 1 ton,so a little fordson van is built to carry 1/4 of a ton!
  #21 (permalink)
Old 09-19-2011, 01:54 PM
malc's Avatar
Born To Be Mild
What´ll it carry when it´s done, a six pack ?
  #22 (permalink)
Old 09-19-2011, 01:57 PM
123pugsy's Avatar
Wiki Edits: 29
Five hundred pounds of beer may be a few bottles more than a six pack.
  #23 (permalink)
Old 09-19-2011, 02:33 PM
5 CWT's Avatar
cwt
Not built to carry,although only weighing 800kgs with a jag axle,289 motor and 400lb rear springs itl now carry me from 0-60 in 3 secs
  #24 (permalink)
Old 09-19-2011, 05:59 PM
123pugsy's Avatar
Wiki Edits: 29
With that low weight it should go like stink.
  #25 (permalink)
Old 09-24-2011, 08:15 AM
5 CWT's Avatar
more pics and "stock heads over after market heads"
Some more pics of "Britains Fastest Van" being built. Engine is currently stripped and being fitted with heavily ported stock heads amongst other goodies new kieth black 116 pistons and a comp xe268h cam any of you guys using a 289 with mods? *** Ive been looking closely at some after market heads this week as im looking to upgrade the power output of my 289 ford hipo engine,I work on the philosophy that if you cant make it or modify it then steal it or buy new! But only as a last resort!!!
The heads ive been looking are edelbrock RPM,trick flow and afr"s.My own stock heads are 289 ford and have come to the conclusion that £1200 in UK for a pair ( minimum ) is not good value for money. Comparing the inlet ports the size and shape is exactly the same as the stock ford,combustion chamber shape and size the same,valves in the aftermarket heads are bigger but are not always necessary,some people over valve their heads leading to sluggish bottom end response and poor vacuum,the only real difference is the exhaust ports being that on stock heads they have a very poor flow rate caused by casting lumps and badly designed shape,this can easily be rectified by a simple porting job,so what are we paying for exactly,the fact that they"re made from aluminium? big deal,the fact they have huge valves,big deal,the fact they have a 5 angle valve job? big deal.
In my opinion a set of correctly ported standard heads which will cost you about £58 for the dye grinder/stones and carbide burrs, matched to the correct pistons and camshaft are as good as any after market heads ( in the case of a ford windsor v8 ) that is,whats your opinion and experience???
ID:	58548   Click image for larger version
ID:	58549   Click image for larger version
ID:	58550   Click image for larger version
ID:	58551   Click image for larger version
  #26 (permalink)
Old 09-25-2011, 10:36 AM
66GMC's Avatar
Somebody put your steering wheel on the wrong side.
J/K ... Looks like a lot of fun!
  #27 (permalink)
Old 09-25-2011, 11:32 AM
5 CWT's Avatar
Hi,cheers it is going to be a promotional vehicle as well as a road rocket! I am an Inventor and have just patented a new golf putting device for practising on grass! Pic not included until release date
  #28 (permalink)
Old 09-26-2011, 06:05 AM
TroyBoy's Avatar
Psychomotors
That van is very cool. I like how you are thinking outside the box. Keep up the good work and more pix please,lol.
  #29 (permalink)
Old 10-05-2011, 10:14 AM
5 CWT's Avatar
Fordson Van
cheers,more updates in the coming weeks!
  #30 (permalink)
Old 10-05-2011, 12:19 PM
MXrider13's Avatar
Can't wait to see it finished
build thread, performance van
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
The new worlds fastest "production" car Blazin72 Hotrodders' Lounge 4 01-25-2008 06:44 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
