"Britains Fastest Van" - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #31 (permalink)
Old 11-01-2011, 02:50 PM
5 CWT's Avatar
Fordson Van
Well,winter is now here in old britain so im back on with the build! Seat rails and prop loops now welded in - home made headers and front pipes fabbed - propshaft - gearbox mounting and servo mount fabbed n fitted,289 heads seriously ported! Fuel tank is this weeks project together with the boot ( trunk ) floor! Thanks for all your kind words everyone Pics of narrowed and modified triumph spitfire front suspension and steering to follow...
ID:	59309   Click image for larger version
ID:	59310   Click image for larger version
ID:	59311   Click image for larger version
ID:	59312   Click image for larger version
  #32 (permalink)
Old 12-30-2011, 03:02 PM
5 CWT's Avatar
Fordson van update
What do you think guys? Britains fastest street van
1 http://www.hotrodders.com/forum/atta...id=61215&stc=1
http://www.hotrodders.com/forum/atta...id=61216&stc=1
http://www.hotrodders.com/forum/atta...id=61217&stc=1
Name:	van rear 2.jpg
ID:	61215   Click image for larger version
ID:	61216   Click image for larger version
  #33 (permalink)
Old 12-30-2011, 06:00 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Sorry, the rear end view with the mufflers is just not doing it for me.
  #34 (permalink)
Old 12-31-2011, 04:14 AM
5 CWT's Avatar
Fordson van update
Hey,no worries,thats what customising is all about,personal taste,I prefer the old school butch look!
  #35 (permalink)
Old 12-31-2011, 06:36 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Right on.
Did you make those mufflers yourself?
  #36 (permalink)
Old 12-31-2011, 10:29 AM
5 CWT's Avatar
Fordson van update
Originally Posted by 123pugsy
Right on.
yes buddy,I couldnt find any to fit the space under the van 16x10x3 inches,hoping they sound good with the tuned 289 hipo!
  #37 (permalink)
Old 12-31-2011, 10:58 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Should sound OK.
Any pics of how they're made?
  #38 (permalink)
Old 12-31-2011, 11:36 AM
5 CWT's Avatar
Should sound OK.
I have taken three pics of the build up. start by cutting two 3mm end plates and hole saw them 2.25 inch for my application,then a length of baffle for each muffler for the length required 16 in my case.. weld the baffle to the end plates keeping them straight in the floor,then draw a centre line through the middle of the correct size tin plate,I used 16x0 inches. then inch by inch tack weld to the boxes,do both ends together or the tin plate will not meet properly.stuff the mufler with loft insulation or glass fibre quite tight,then fully seam weld. ; ) pretty basic stuff...[IMG]
http://www.hotrodders.com/forum/atta...id=61264&stc=1
  #39 (permalink)
Old 12-31-2011, 11:41 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Interesting.
Looks like I could add some more muffling (word?)
to my exhaust system if I find its too loud.
  #40 (permalink)
Old 12-31-2011, 11:47 AM
5 CWT's Avatar
Interesting.
yes but if you stuff it too tight it has the reverse effect!
  #41 (permalink)
Old 12-31-2011, 02:45 PM
Last journal entry: update
Awesome idea, basically. Do it as a 347 stroker with AFR 185 heads and the FMS E303 legal cam, it'll do 450 HP no problem, still daily street driveable, and run forever. Forget the c4, do a wide-ratio AOD. The OD with a 3.54:1 should still make the 347 do 25+ MPG. And this combo should actually be capable of your dream of 0-60 in 3 seconds. No point sticking with obsolete parts. If you can't afford to do it right the first time, then no sense doing it at all.
  #42 (permalink)
Old 12-31-2011, 03:49 PM
5 CWT's Avatar
Fordson van update
Hi
Not for me on the stroker,its standard 289 but 40 over with a crower level 3 beast cam,edel rpm intake,600 edelbrock,roller rockers,about 375 bhp on UK fuel,good recommendation on the g/box tho but its only for street use and our streets in the uk are only small! http://www.hotrodders.com/forum/atta...id=61270&stc=1
  #43 (permalink)
Old 01-05-2012, 08:49 AM
TroyBoy's Avatar
Psychomotors
Looking good and I like the muffs!
  #44 (permalink)
Old 01-05-2012, 12:50 PM
5 CWT's Avatar
Fordson van update
Cheers Toyboy...
  #45 (permalink)
Old 01-15-2012, 02:18 PM
5 CWT's Avatar
http://www.hotrodders.com/forum/atta...id=61874&stc=1
build thread, performance van
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 08:18 PM
The new worlds fastest "production" car Blazin72 Hotrodders' Lounge 4 01-25-2008 07:44 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 01:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
