British question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 01:32 PM
British question
Hi guys
Can anyone tell me the American version of a swirl pot?
What is a swirl pot I here you ask?
Fuel collector header tank to gravity feed the injection pump.
A device in a fuel tank (or externally) that prevents bubbles getting into the fuel system allowing a constant fuel delivery.
http://www.demon-tweeks.co.uk/resour.../ATLITC305.jpg
Many thanks Paul
Old 02-27-2008, 08:25 AM
Holder350's Avatar
Auto Parts Professional
ok....I cant find anything, but I'v heard them called a surge tank also.
Never heard them used for fuel before tho, mostly I'v seen them used on dry sump oil systems. The surge can directs the oil coming into it onto the wall of the can and spins the air out of it, it then collects at the bottom to be sucked up by the pump and back thru the motor.
I'v looked thru my catalogs and I cant find any of these made for fuel BUT....
http://www.jegs.com/i/Stef's/861/4110/10002/-1
Old 02-27-2008, 10:22 AM
Banned
you would only need those for a returnless fuel injection setup. Almost all fuel injected cars in the states are running a return style fuel setup so we have no use for something like that. My recomendation is to switch to a return style fuel system, its a cheaper, more effective method.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
