brodix -8 head - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2008, 06:35 AM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
brodix -8 head
i want your opinion on this aluminium head drodix -8 62 cc combustion chamber
2.o5 1.60 valve spread port exhaust flange the is going on 383 roller cam 10.8 compression ratio air gap intake
Old 07-22-2008, 06:58 AM
SSedan64's Avatar
What are you plans for the engine? Strip or Street? Or mostly street & some strip use? Those are some serious heads 3500rpm & up. Plus spread ports are hard to find headers for without spending major $$. The Track 1 may be a better choice.
Old 07-22-2008, 01:11 PM
i already have the header the head in chevy truck only the cab on the frame dana 60 and 14 bolt 44 bogger 4.56 ratio th 350 2600 stall
Old 07-23-2008, 11:29 AM
what about putting this head on a 327 or 302 and make a screamer
Old 07-23-2008, 02:21 PM
SSedan64's Avatar
They would work better with a little larger engine but could be made to work with on the 302 or 327. The recommended rpm range for the -8 is 3800-6800 on a 355-377ci engine with a Min. of 11 to 1 compresssion. Those heads would raise the required rpm range higher on a smaller engine to maybe 4400-7500rpm. It would definetly be a screamer,
http://www.brodix.com/heads/-8.html
For your truck you want a head with smaller intake runners that will produce plenty of bottom end torque to turn those huge tires.
Old 07-23-2008, 03:32 PM
the intake runner is 194 cc not too big for 383 i think?
Old 07-23-2008, 03:35 PM
but i dont know how much cc on exhaust side
Old 07-23-2008, 03:45 PM
i have a 327 here with domed l-79 piston but i dont know if i the piston clear because of the heart shape of the head
Old 07-24-2008, 01:19 AM
SSedan64's Avatar
The old style dome pistons usually don't clear with the newer heart/kidney shaped chambers. You could check them with modeling clay, just be careful when rotating the engine if you feel any resistance. You may want to do this with only 1 piston installed at a time so it's easier to turn & feel interference.
VW Jetta Cylinder Head Chevy21 Engine 2 02-13-2008 09:04 AM
SBC HEAD QUESTION: Need Help Picking A Head Mustangsaly Engine 11 12-01-2007 01:02 PM
Head Gasket Selection!!! sexypizzaman Engine 2 09-21-2007 09:37 AM
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
which head to use? sune Engine 8 03-07-2004 01:44 PM
