For the record from Wiki:
400 The only 400 cubic inch size of this family, 400 cu in (6.6 L) small-block, was introduced in 1970 and produced for 10 years. It was loosely based on the 'medium' journal 350 and had a 4.125-inch (104.8 mm) bore and a 3.75-inch (95.3 mm) stroke. The 400 differed from other small blocks in that the cylinders were cast siamesed, used a 2.65" 'large' main bearing journal, and oftentimes had one more core/freeze plug on both the left and right sides of the block. Initial output was 265 hp (198 kW) and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced, while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in full and mid-sized Chevrolet Passenger car, available in both A-Body and B-Body lines. While popular with circle-track racers and drag racers, the engine could be prone to cooling problems if cylinder heads without added steam holes were used. And from E-question: Engine HP Specs for 1970 to 1980 Chevy 400s Written by moss strohem Engine HP Specs for 1970 to 1980 Chevy 400s The Chevrolet 400 CI small-block engine was introduced in 1970 and remained in production until 1980. It was an "in-between" engine option, fitting in the middle of the 350- and 454 CID Chevy engines. Design and Applications Based on the original SBC platform, the 400 engine used a crankshaft stroke of 3.75 inches (1/4 longer than the 350 SBC) and a 4.125-inch cylinder bore. It was -- as a large-displacement, small-sized engine -- used in Chevy full-size cars and light-duty pickup trucks. High horsepower was never the intention for the 400 SBC. Rather, the increased torque from the greater displacement made it suitable for heavy vehicles. Standard Performance Output The highest rated output for the 400 SBC occurred in 1970 -- 265 horsepower. Horsepower declined throughout the 1970s due to a combination of increased emissions requirements as well as measuring the output at the rear wheels (net) as opposed to at the engine flywheel (gross). At its lowest, output was rated at 150 to 180hp. You can search any number of reliable sources,myself included,that advise drilling the steam holes.In my professional opinion drilling steam holes in non 400 heads has no relevance to the thin OEM 400 block decks. |
Curious as I always have been,I had to go search for the Turbo-Fire 1970's 400's spec.Honestly I didn't find the compression ratio,maybe it would be in a repair manual.Still,a two barrel 265hp engine in what would be at best a 3500lb car running 13 seconds in OEM trim,I am having a hard time wrapping my head around that.That is 43 yrs ago.
The, my 1970 400 engine was stock other than headers and dual exhaust. Was in a 68 chevelle with 3.73's.
Some of us don't need to search on Wiki. Some of us were actual there and had these engines. Factory rated at 330hp. These 1970 330hp 400's had flat top pistons and the 487x head 1.94x 1.60 factory valves. The cr was 10.25:1. With headers it had to have been 360hp. Made a ton of torque. I had a factory GM Qjet intake and a Qjet off my old 396, on it. It had th stock cam. 195-202-.390-.410 112. the "929" cam. I took this 330 HP 400 SBC from a 1970 Impala. I ran this for few years. Then, one winter the block cracked from not enough antifreeze. this I did need to look up.: The 1970 330hp 400sbc engine RPO code was "LS3". The 1970 2 bbl 265hp 400 was a different low cr engine RPO code "LF6" Last edited by F-BIRD'88; 01-16-2013 at 07:15 AM. |
The RPO code LS3 in a 1970 Chevelle was at 330 hp a BBC 402.
At this pointless post I just made,I refuse to waste anymore time on a topic having nothing to do with the O/P's question.Furthermore,I refuse to be the second party hi-jacking this thread. |
It was a 400/330hp SBC from a 1970 Impala. And the RPO code was LS3. There was actually three difference 1970 engines that year that had the same RPO code LS3. |
Its a callies crank compstar h beam rods and mahle pistons its a complete rotating assembly im getting it internally balanced do i need a 350 damper and fly wheel since its internally balanced thanks for all the info
| Brodix heads | 67-4-fun | Hotrodding Basics | 9 | 01-06-2012 05:57 PM |
| brodix rr or 049s | 72olds | Engine | 1 | 03-21-2011 03:58 PM |
| Brodix Heads | streetrodderbn | Engine | 7 | 02-06-2010 04:47 PM |
| brodix -8 head | chevrolet327 | Engine | 8 | 07-24-2008 01:19 AM |
| Brodix manifolds | stfinney | Engine | 1 | 11-03-2002 02:05 PM |
