brodix ik200 question - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-16-2013, 10:19 PM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Yep.I'm liking the direction your going with this.
  #32 (permalink)
Old 01-17-2013, 09:09 AM
gamedawg03's Avatar
Do you think that would be a good rotating assembly to go with
  #33 (permalink)
Old 01-21-2013, 01:10 PM
gamedawg03's Avatar
Sent.my heads to machine shop to get steam holes drilled in them
  #34 (permalink)
Old 01-21-2013, 01:26 PM
F-BIRD'88's Avatar
Yada Yada Yada
Thats a beautiful thing...
  #35 (permalink)
Old 01-21-2013, 10:30 PM
gamedawg03's Avatar
I appreciate all the info, im getting them port matched with my intake
  #36 (permalink)
Old 01-21-2013, 11:45 PM
malc's Avatar
Born To Be Mild
On the Brodix F.A.Q. website page it says not to drill steamholes.
  #37 (permalink)
Old 01-22-2013, 10:57 AM
gamedawg03's Avatar
Has anyone seen the kmj performance assault torque converters and are they any good
  #38 (permalink)
Old 01-22-2013, 12:01 PM
F-BIRD'88's Avatar
Yada Yada Yada
You get what you pay for.
  #39 (permalink)
Old 01-22-2013, 07:48 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Your statement is misleading. Looks like to me what they are actually saying is that the heads are manufactured with holes that match up with the holes in the block and that you must make sure the holes are drilled in the gaskets. Read it for yourself......
Q. Do you recommend steam holes on BRODIX heads?
A. No, the BRODIX water jacket is more efficient than previous heads. Just make sure all holes are properly lined up and drilled in head gaskets to efficiently pass water.
  #40 (permalink)
Old 01-22-2013, 10:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Brodix says no steam holes. Period. That was confirmed to me some time ago. What is being talked about are the head gasket/block coolant passages, in some cases they don't line up as well as they could and need to be located better. There are also things to look out for on the head gaskets, as shown here: Small Block 400 Cooling Tricks.
FWIW, Joe Sherman doesn't use them. But he'll gladly do them for others. For a fee, of course.
As far as a 325 hp 10.25:1 sbc LS3 2bbl 400, I'll have to pass on that one. lol Except to say the only engine I know of that comes close to that was a 402 BBC. Another odd engine was the 265 hp bbc 396/2bbl.
  #41 (permalink)
Old 01-22-2013, 10:45 PM
1Gary's Avatar
Well they changed their advise.
  #42 (permalink)
Old 01-22-2013, 10:49 PM
malc's Avatar
Born To Be Mild
My statement is not misleading, they say no steamholes.
They do not say the heads already have steamholes, I read it that all the regular holes for water are checked to be lined up and clear.
Nowhere does it say there are steamholes in existence.
Anyway the original poster completely ignored my post so what do I care how you read it ?
  #43 (permalink)
Old 01-22-2013, 10:56 PM
malc's Avatar
Born To Be Mild
I have a 350 so steamholes are not an issue.
These are my IK200 heads check them out for steamholes.
Click the pic to enlarge it.
  #44 (permalink)
Old 01-23-2013, 09:34 AM
F-BIRD'88's Avatar
Yada Yada Yada
This 400sbc was not a 2bbl engine. It was a factory 4bbl engine with factory flat top pistons and the 487X heads with factory 1.94x 1.60 valves.
The 487X head had a slightly larger intake port and probabily the best exhaust port of the like heads. It was factory rated at 330HP and was a true 10.25:1cr
It was only offered in the 1970 Impala. (I had seen these 400's in the Impala before and when the opportunity came up to buy one, I did. I bought the whole car. I knew exactly what it was, when I bought it.)
if you search a bit you will find mention of it.
It is mentioned in the larger versions of the Motors Manual and in the book Fix your Chevrolet. I got this stock 400 -330hp 10.25:1cr motor out of a used 1970 Impala. It made real good power in my 68 chevelle. Only the 454 I built and ran back then ran faster.
This was no 265Hp 2bbl motor. I installed Z/28 valve springs to get more rpm butr never cammed it.
I disassembled it after the block froze up. All stock GM internal parts. As stated.
I had a stock intake-and Qjet and a Edelbrock street master-750VS on it and headers and GM Z/28 valve springs. All else was stock GM. The stock GM springs were tired and it would not rev over 4500rpm with them.
It would rattle like a pig if you tried to use regular gas. Was not a big rever (stock cam) but pulled like a freight train.
These factory high compression ratio OEM 400 4bbl engines existed, just not widely known of especially by those that were not there at the time.
A friend here had one of those factory odd ball 2bbl 396 motors a 1969 chevelle w powerglide.
  #45 (permalink)
Old 01-25-2013, 03:29 AM
Since this topic is here. Let me know how your engine runs. I'm getting these heads as well and I've seen a few reviews of them but no ongoing discussions.
The Following User Says Thank You to Deathmunchy For This Useful Post:
TMF Lindbeck (01-31-2013)
Brodix heads 67-4-fun Hotrodding Basics 9 01-06-2012 05:57 PM
brodix rr or 049s 72olds Engine 1 03-21-2011 03:58 PM
Brodix Heads streetrodderbn Engine 7 02-06-2010 04:47 PM
brodix -8 head chevrolet327 Engine 8 07-24-2008 01:19 AM
Brodix manifolds stfinney Engine 1 11-03-2002 02:05 PM
