I have a victor jr now but im getting a super victor im not sure if it has it in the back of the manifold also i have a weind water pump but there no place in it or the victor jr for for alternator bracket
If you are upgrading to a super victor,we are talking serious power and high RPM? Are the heads ported a lot? I would probably drill the steam holes,or if you are making big power,think about an after market block.
Here is an outline of the procedure if you decide to drill the holes.....
Technical Articles at Greg's Engine & Machine In my opinion, I wouldn't run a 400 without them. GM engineers found a need for them at low rpm's. Steam pockets would form at the blind corners of the water jackets as a result of the cylinders being siamesed. These pockets of steam would heat that little area and either cause pre-ignition or would cause the motor to spit out the head gasket. I am unsure as to whether or not the engineers tried running a hose from the back of the heads to the water pump, but if they did, it apparently didn't work as well as drilling the steam holes because I know of no factory bypasses, only steam holes. No steam holes are needed if the motor is to see duty in the higher rpm range, such as in a racing application. The speed of the water through the water jacket due to higher water pump impeller speeds will wash away any steam pockets that may try to form. It's only a problem at lower rpm's. Last edited by techinspector1; 01-15-2013 at 01:57 PM. |
Here is apic of trhe rear water port on a tunnel ram.
its on the drivers side, not the passenger side. I have another pic of a origional 1964 GM 327-375HP fuel injection intake manifold that also has the water port on the driver side specificly, also. I cannot find it. Remember this is prior to the emissions era which started in 1966. Thats when GM started with the hotter engine idle temp design. to aid emissions. Hotter water temp at idle- generally less idle spark advance which make the heads and top of the block run hotter at idle. Thats part of the reason a stock 1970-71 400 SBC has a reputation of running hot. Truth is all the engines of the 1970 to 1975 era tended to run hot. By design. Retarded idle ignition timing. Makes a big difference. And generally makes any engine run hotter at idle. See that's the difference--- real world experience and real world context. Some stuff in this worold was done before the internet came along. I had a original 400 SBC years ago and went thru all this stuff, then. Try the water port mod, with or without the steam holes. You'll find it works real good on your 400 and on SBC's in general. Last edited by F-BIRD'88; 01-15-2013 at 02:55 PM. |
Sounds like instead of steam holes drilled in the heads,that we all know about;you could also look for an antique intake manifold that GM made or a very old cast aluminum intake that was designed for engines that not only preceded the 400 small block,but also preceded the 350 small block.
Im looking for a serious street and strip motor. This is my first serious motor being built, i have had all the machine work done to it i have been looking at rotating assemblies in cnc notorsports website. The one i looked at says its 11.6 cimpression with 64 cc heads .im getting my heads port matched and bowl blended and putting 2.05 valves in them my question is what would be the best way to go for cam for best power on street and strip a retrofit roller or solid roller
Let's break down the steam hole question.
We know we bore/hone 400's with torque plates mainly because the design of the 400's bores move around alot. We know the 400's where never designed for high performance use.They where never intended for high compression use.I.E.:76cc heads We are very sure with increased output=increased heat. Now I worked at the Chevy engine plant as a engine tester when the 400's where new.Also my racing operation over the yrs in 9.90 cars of 17 last count cars used 7 400's of various size.All of them with steam holes drilled. We know mainly because of the well documented issues the OEM 400 blocks have is the reasons why the aftermarket blocks where designed as they are. The summation of this is if not for the leakdown sealing issues the 400's have,there isn't a sound reason not to have the steam holes drilled. As a side comment.Any suggestion not to drill those holes is confusing as the reason.Or to run bypass hoses.At best that is very dated.At the worst it is to draw attention to themselves knowing it is argumentative post.Certainty drilling the steam holes is a proven preventive method. If your asking which cam type would be the king of the hill given your SCR,a roller solid lifter with a rev kit is the way to go as long as you don't mind setting the valves.Certainly you have to have the springs for it and check the clearances. |
Had me back tracking here.Long before you buzz this 406 up,need to know that the rods you have/rod bolts can cover that kind of stress.Also IF you go solid roller lifter cam/kit,most are going to leave something on the table on the lower rpm ranges.Almost all are going to need a loser T/C and gears.
BTW-love that brand name heads.We have used them(maybe not this model,but)have had nothing but good results. |
| Brodix heads | 67-4-fun | Hotrodding Basics | 9 | 01-06-2012 05:57 PM |
| brodix rr or 049s | 72olds | Engine | 1 | 03-21-2011 03:58 PM |
| Brodix Heads | streetrodderbn | Engine | 7 | 02-06-2010 04:47 PM |
| brodix -8 head | chevrolet327 | Engine | 8 | 07-24-2008 01:19 AM |
| Brodix manifolds | stfinney | Engine | 1 | 11-03-2002 02:05 PM |
