broke or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2006, 09:43 PM
broke or not
i was drag racing and when i went to take off the truck wouldn;t go and revved up i finally go it to move and it sounded like someone was beating a hammer against my tranni
Old 04-07-2006, 09:46 PM
97Z28's Avatar
NTI Grad.
the tranny is slipping, and when it finally caught hold it ripped off the tranny mount. thats what it sounds like to me anyways, from the info you've provided. is it an auto or manual?? did you check the fluid level?? what year truck?
Old 04-07-2006, 09:48 PM
its a manual saginaw 4 speed ina 92 chevy shortwide
Old 04-07-2006, 09:53 PM
97Z28's Avatar
NTI Grad.
how high was it revved when you dumped the clutch?
about 3 thousand
docvette's Avatar
Wiki Edits: 12
Doc here,
That, OR an input shaft yoke U~joint..or a u~joint bearing..
you might want to look and see if the drive shaft is bolted in on both U clamps..and not sitting offset..
While your down there, shake it up and down..It should not move.
What did you do, rev it up and drop it in gear..? Tears up the drive line but good.
Doc
Old 04-07-2006, 09:55 PM
i had it in gear before i took off i t revved up and moved a bout 2 feet it will go 2 throug 4 but nothing in 1st
Old 04-07-2006, 09:59 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OK, being a manual instead of an automatic..Sounds like you busted first gear right off it's shaft..might want to drain the oil look for metal, and run a magnet around inside it..if you find any..time for rebuild..
Doc
Old 04-07-2006, 10:01 PM
dang i was afraid of that thanks for all the help that breaks my heart i loved that tranni
Old 04-07-2006, 10:37 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
So don't give up on it then..It's Probably highly rebuildable..assuming no case damage was done..
Place to start is look for metal in the oil..and run a telescoping magnet around inside the oil filler hole..If you get metal , pull it and inspect to see if it can be rebuilt..
Doc
Old 04-07-2006, 10:42 PM
thanx
They both broke OneMoreTime Hotrodders' Lounge 5 06-08-2005 07:24 AM
9 signs you're broke ChevelleSS_LS6 Hotrodders' Lounge 14 11-04-2004 08:47 AM
Little broke people sway Hotrodders' Lounge 31 07-02-2004 07:35 PM
Posi-trac Experts (If it ain't broke, should I fix it?) Axelrod Transmission - Rearend 3 05-21-2003 05:23 PM
Broke in and running GREAT 56wagon Engine 6 07-25-2002 03:25 AM
