broke shock bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2011, 09:19 AM
broke shock bolt
When I bought the truck it was already broke. Its lowered too.
I've tried to drill it out but that heavy duty steel keeps breaking the bits.
its like a 1/2 inch bolt. Should I just drill a hole in another location so I could place the shock there? Cause that thing IS IN THERE!!
Any input is greatly appreciated.
Old 11-22-2011, 10:33 AM
sqzbox's Avatar
My pipes are my music
Have you tried the 4 1/2' angle grinder yet? worked for me on my chevy 3/4 4x4.
Old 11-22-2011, 10:51 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
If you can get in there to weld a nut to the stud, Add a little heat spray it with some lube... And back it out....I would do what ever it takes to get it out.... Post a picture and we just may have another idea for you..
Old 11-22-2011, 11:02 AM
Last journal entry: My Last Hot Rod
Get a decent drill bit
They make drills that will drill that bolt, not to costly either, Those bits that come in a little case are usually junk. Go to a local machine shop and ask them what drill to use they know
Old 11-22-2011, 11:25 AM
Thanks for the help guys.
The next time Im around my machine shop ill ask.
Old 11-22-2011, 05:43 PM
1971BB427's Avatar
I'd take a nut from the same size bolt and hold it over the stub, then weld the inside to the stub. Before it totally cools put a socket on it and it will likely come out.
bolt broke off in 454 block sam109 Hotrodding Basics 4 03-25-2010 05:52 AM
Broke Strap Bolt V8 Super Beetle Transmission - Rearend 6 02-17-2010 03:48 PM
Bolt broke Mr.NutCase Garage - Tools 5 01-19-2007 12:54 PM
broke bolt bigtim General Rodding Tech 5 05-09-2006 06:05 PM
broke bolt bigtim Transmission - Rearend 6 05-07-2006 03:16 PM
