Broke temp bulb in SB - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2007, 01:34 PM
I replace the thermostat cap (old one broke and has the temp sensor bulb on it) in a SB, intending to use the sensor bulb on the drivers side on the engine but didn`t work. I try to change it and I broke it, leaving the core with nowhere to grip it.
Appreciate any trick to get it out, or where to locate a new bulb easily.
Thanks.
Old 10-21-2007, 06:39 PM
bondo's Avatar
Ayuh,......
An appropriate sized EZ-out,..??..??.....
Old 10-22-2007, 12:45 AM
EZ out?
EZ out? what is it? Nothing under that name down here (Chile)
Sized? Uhhh, a counter thread drill bite? If so, what will happen when I drill the bulb to get the counter thread in?
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 03:04 PM
Broke temp bulb chileelky Hotrodding Basics 7 11-14-2007 07:20 AM
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
