Broke valve cover bolt help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2012, 08:01 AM
Ok so I got a 454 out of a 79 Burban and I wanted to se what heads it had so I took off the valve cover and it has the 781 oval ports and when I was tightening up the bolts on the top of the valve cover all the way on the right snapped of flush with the top of the head and I have no idea how to get it out please help
Old 08-08-2012, 09:35 AM
Jimbo17's Avatar
Nostalgic Racing Decals
EZ Outs might be the answer.
There is a tool called an Easy Out which may help you.
Any auto parts store or a Sears store would have them.
They come with drill bits and a tool you insert into the small hole you drill and then you turn it to the left and with a little luck you just might find the rest of the broken bolt will come out without using an heat on it first.
Give it try. Jimbo
The Following User Says Thank You to Jimbo17 For This Useful Post:
79 trans am kid (08-08-2012)
Old 08-08-2012, 09:44 AM
What I would try first is to weld a 5/16 nut to the remaining piece. I have much more success welding to the bolt than drilling them out with a hand drill.
The Following User Says Thank You to lmsport For This Useful Post:
Old 08-08-2012, 10:32 AM
Thanks for the info guys I'll try to weld a nut on it the remainder of the bolt is just shy of the top of the head but their good heads aren't they?
Old 08-08-2012, 11:37 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You know, if that bolt isn't bottomed out in the hole, you might be able to use two sharp picks and turn it out, I've done it before.
Semper Fi
Old 08-08-2012, 11:47 AM
Banned
If there's enough left just slot the top with a dremel and use a screw driver to back it out.
The 781's can be decent heads with enough work (ie time and or money).
Old 08-08-2012, 01:12 PM
Ok well I guess I'll try to weld to it cause I can't cut a slot in it the weld won't stick to the head right
Old 08-08-2012, 01:16 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
everything you ever wanted to know is right here:
http://www.crankshaftcoalition.com/w...tuck_fasteners
Old 08-08-2012, 01:35 PM
My dad says that the ez out would be my best bet thank you guys for all the ideas
049, 781, head, valve, valve cover
Valve cover bolt question. rajsid Engine 3 06-13-2009 09:58 PM
Center Bolt Valve Cover stfinney Engine 4 05-19-2008 09:24 AM
Valve cover bolt ucmung Engine 9 01-26-2007 06:58 AM
Center bolt valve cover adapters? Marcus Engine 14 03-24-2004 03:28 AM
over drilled valve cover bolt jrm123180 Engine 3 02-27-2004 07:14 PM
