Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - broken block 350 starter bolt hole
Old 02-01-2013, 02:15 PM
timothale timothale is offline
Wiki Edits: 27
mis alignment
If the starter is not properly smimmed for gear to flywheel clearance. if wrong bolts used etc . you end up with broken out holes or broken starter nose casting. Also the factory had a brace that holds up the end of the starter.
Go to the Wiki link at the top of this page, then click on engines, then when on engine page click on starters, ther are 3 or 4 pages of starter information
